I bought and sucessfully installed my v2 with 7.3 software on a desk top PC windows XP 32 bit back in 2007. Then I got my 64 bit Vista laptop and tried about every thing I could find here to get the right USB drivers going and I can't.
To load drivers:
- Connect FlashScan to your laptop.
- Right-click on the ‘My Computer’ icon and select the ‘Manage’ option’.
- In the left hand tree select ‘Device Manager’.
- If the drivers are loaded you should see a device with ‘FlashScan’ in the
name under the ‘Universal Serial Bus controllers’ section. If not it will
be listed as an ‘Unknown Device’.
- If it is shown as ‘Unknown Device’ right-click on the ‘Unknown Device’ and
select the ‘Update Driver Software’ option. The drivers are located in the
‘C:\Program Files\EFILive\Drivers\EFILive\Win-2K-XP-Vista’ folder, so choose
the ‘Browse my computer’ or advanced options and select this location to
search. Don't be tempted to navigate the extra folder level into the 'amd64' folder, which I suspect is what you might be doing.
I was tempted. Story of my life. Thanks for the quick fix.
Also, make sure you are running the latest software. 7.3 is really old, we're on 7.5.6 build 104 now. :)
Good call. Hadn't noticed the 7.3 reference. If you have a FlashScan v2 device your firmware is going to be horribly out of date also. Before updating the firmware please read fully the 'C:\Program Files (x86)\EFILive\V8\Documents\Upgrading FlashScan.pdf' document.
Ha. That is one of the few times I have been able to leave the (x86) reference in the path from my 64 bit system. Usually remove it to avoid any confusion :)
i just got a laptop that has a Windows 7 64-bit OS... I followed the above mentioned directions, but i am still getting a Win32 (needs evaluation) 740 error.
I can see in the device manager that EFI Live FSP is installed and working properly, however i can't even install it because of this error.
HELP..
Disregard above post. I installed it using the download from the site. It worked flawlessly.
