Seems like this map is pulling a lot of timing. Do you guys even use this map, or do you just zero it out?
I've stared at those tables more times than I'd like to admit, yet haven't tried changing them. For the reason I can't see where it's pulling 10 degrees or more at 2000 rpm or above. I'm waiting for our "new and improved" data logging operating system to come out, maybe we'll see what comes out of the woodwork with that...
The table does word and makes a difference for control and boost
Log you tune then play your tune back and open the boost table, look in see what your log is showing in boost table. Start there, then you can see how much fuel you need in that boost area of the map.
Help you out 14.5 is idle area for most of our trucks. Basically 14 is 0 psi on the mechanical gauge if u have one on ur truck
F0502 Fuel Limiter, Boost
Sorry: my bag
