Programming the Intake Air Valve for a Positive Air Shutdown
There is a thread going in the Diesel Place forum regarding using the IAV for a positive air shutdown. http://www.dieselplace.com/forum/sho...24#post1836724
We've tested with a Tech II commanding the valve closed, and it will shut the motor down. In the oilfield, it is regulated that we have a positive air shutdown to keep diesel engines from running on other combustibles i.e. a natural gas release. Normally we have to hack in a big valve in the air intake, wired to an rpm switch and a manual switch. But it would be nice to use the existing IAV and integrate that with ECM control.
Is there any possibility in introducing programming for this on the LMM?
