please add
cruise control parameters
please add
Such as?
dead band amounts
amount of correction based on error amount
min max speed
etc
Cruise isn't controlled by the ECM, and will not be considered.
Cheers
Cindy
Don't think this will be a prob. when csp5 comes out for you could have 1 file or hard wire the pin for 6th file for you high idle. This was my plan there for it would not be a loaded high idle [ie] like it is now technically is a pto function.
cummins ecu's have always controlled the cruise. if this is one the doesn't do you have any idea what module does?
thanks
two things
can you add ability to select wether ecm listens to skim system
(another words ignore any security stuff. like if i don't want to use skim keys or use engine in an another application)
this would also solve the wrong vin used (oops) tow to dealer problem.
and be able to select (activate) one of the five tunes when (tow\haul) is activated
(that way we could set of a tune (especially trans stuff) automaticaly when (tow\haul) is active
thanks
justin
Whats in csp is what you got. No further changes will be made to my knowledge. Isn't it just as easy to turn the knob when you press tow haul, its one more step.
This would be an easy thing for you to add
I don't want to plug in programmer just to select a different shift schedule
would be a great feature for tune shops too
And ability to ignore all the vin checks and security crap would solve many problems
A desired boost table like the lml's have would be nice.
