In my search for a better 60 foot time I'm looking for ways to build boost. From the tutorialIs anyone using this to build boost off the line? How long is too long?Quote:
The Valet mode RPM limiting uses fuel cut-off to limit the engine RPM, it does not use spark cut. It is not recommended you hold the engine on the RPM fuel cut for very long as the engine can run lean and damage the engine itself and/or catalytic converters, use it sensibly.
