Results 1 to 10 of 11
Thread: where can I find 0411 pcm ?
    Feb 2009
    Default where can I find 0411 pcm ?
    hi I'm looking for 0411 pcm for my truck
    where can i find it ?
    Its came in which car ??
    Apr 2008
    look for a 2002 express van then it already the operating system you need
    just needd it tuned for vats rermoval and other little things vats is the main on you can drive with the other ones
    stock sucks
    Lifetime Member Aloicious's Avatar
    Nov 2007
    Quote Originally Posted by tokymon View Post
    naw, just get one out of anything, it'll be much harder to find one specifically from a '02 xvan. it'll need to be tuned for the VATS and other stuff anyways, so its no harder to change the OS at the same time.
    they came in MANY MANY vehicles from around '99 to '08. mine came from a '02 camaro I believe. you can find them in junkyards, classified ads, eBay, swap meets, anywhere carparts may be found, just look for 12200411
    Mar 2007
    12200411 may be an F-body and Vette service number only. I think the trucks use a slightly different PCM (different how, I have no clue), and in any case it is the 02 Xpress Van calibration that you need loaded into ANY capable PCM. Someone just figured out the 12200411 will adapt for MANY MANY GM vehicles (possibly the most for one PCM service number).
    I'm pretty sure you can use _most_ if not _all_ (but I cannot confirm this) PCM's that are 512k, unless anybody knows of any specific exceptions. (Maybe the 97-98 Vette PCM's? Quite possibly those are no good to use!)
    Nov 2007
    Quote Originally Posted by Stealth97 View Post
    unless I'm mistaken, all 12200411's are 512k, the 97-98 vette PCMs aren't 411's, the number I found for them is #16232148, though that could be wrong, either way, they look quite a bit different than the 411 too.
    this is rock auto's list for the 411 PCM usage. I actually think theirs isn't complete, but a good basis. one from any of these vehicles should work, just make sure its actually a #12200411. there are 1mb PCM's from later vehicles which look just like the 411 with different colored connectors.
    CADILLAC ESCALADE 2002
    CADILLAC ESCALADE EXT 2002
    CHEVROLET ASTRO (2001 - 2002)
    CHEVROLET AVALANCHE 1500 2002
    CHEVROLET AVALANCHE 2500 2002
    CHEVROLET BLAZER (2001 - 2002)
    CHEVROLET BLAZER TRAILBLAZER 2001
    CHEVROLET C3500 PICKUP HD 2001
    CHEVROLET C3500 PICKUP HD CHASSIS CAB 2002
    CHEVROLET CAMARO SS (2001 - 2002)
    CHEVROLET CAMARO Z28 (2001 - 2002)
    CHEVROLET CORVETTE (2001 - 2003)
    CHEVROLET CORVETTE Z06 (2001 - 2003)
    CHEVROLET EXPRESS 1500 (2001 - 2002)
    CHEVROLET EXPRESS 2500 (2001 - 2002)
    CHEVROLET EXPRESS 3500 (2001 - 2002)
    CHEVROLET S10 PICKUP (2001 - 2002)
    CHEVROLET SILVERADO 1500 (2001 - 2002)
    CHEVROLET SILVERADO 1500 HD (2001 - 2002)
    CHEVROLET SILVERADO 2500 (2001 - 2002)
    CHEVROLET SILVERADO 2500 HD (2001 - 2002)
    CHEVROLET SILVERADO 3500 (2001 - 2002)
    CHEVROLET SUBURBAN 1500 (2001 - 2002)
    CHEVROLET SUBURBAN 2500 (2001 - 2002)
    CHEVROLET TAHOE (2001 - 2002)
    GMC C3500 PICKUP HD (2001 - 2002)
    GMC JIMMY 2001
    GMC JIMMY ENVOY 2001
    GMC JIMMY SLS 2002
    GMC SAFARI (2001 - 2002)
    GMC SAVANA 1500 (2001 - 2002)
    GMC SAVANA 2500 (2001 - 2002)
    GMC SAVANA 3500 (2001 - 2002)
    GMC SIERRA 1500 (2001 - 2002)
    GMC SIERRA 1500 HD (2001 - 2002)
    GMC SIERRA 2500 (2001 - 2002)
    GMC SIERRA 2500 HD (2001 - 2002)
    GMC SIERRA 3500 (2001 - 2002)
    GMC SIERRA C3 2001
    GMC SONOMA (2001 - 2002)
    GMC YUKON (2001 - 2002)
    GMC YUKON DENALI (2001 - 2002)
    GMC YUKON DENALI XL (2001 - 2002)
    GMC YUKON XL 1500 (2001 - 2002)
    GMC YUKON XL 2500 (2001 - 2002)
    OLDSMOBILE BRAVADA 2001
    PONTIAC FIREBIRD FORMULA (2001 - 2002)
    PONTIAC FIREBIRD TRANS AM (2001 - 2002)
    Feb 2009
    so it's if to my truck ?
    I have a 99 GMC yukon slt 2wd with l31 4l60e blackbox pcm
    what I need to swap to 0411? if any1 had a pdf file for that (swaping)
    Mar 2007
    Quote Originally Posted by ammarii View Post
    1. Contact Lextech for the correct file. Everyone got them from him. He is the originator. If Lextech cannot help in a timely manner, I'll send you one of mine. But they are his to give out, not mine to give out. (His are more current anyway, mine are older revisions of the same thing)
    2. You need the Excel spreadsheet, some tools, some knowledge, one PCM (programmed correctly and without VATS), and two connectors for the PCM.
    3. 4 Wires (about 10 feet in length or less, maybe 15 but I doubt it). And 4 ways of splicing those wires into some stock trans wires. Also, 4 crimp pins for installing on the PCM side. Get the pins and wire from S10Wildside and his website called www.eficonnection.com or EFI Connection.
    If you really want to be a wild man in the future after you get the 12200411 swap done, swap to LS1 coils on your old skool 350 chebby. S10Wildside sells the conversion parts to run a true LS1 setup on a true 350 inch motor (not a measly 346, I want my 4cu in., oh and torque)
    If you live in Los Angeles, I'll do the swap with you and teach you how to do it. 2-3 hours. I might have spare wire from when I did mine.
    Feb 2009
    thanx man for ur help
    but i'm not from LA or even US :P
    but I hope its will help
    thanx again n if get stuck in something I'll try to find u
    Feb 2009
    I like this 1 about LS1 coils on old skool 350 its realy sounds good to
    Aug 2006
    Amarrii,
    2001 and 2002 model year GM vehicles used the 12200411 PCM the most. It doesn't matter what model you get the PCM from. Other PCM service numbers will work, but why bother---Just get a 12200411 and program it as previously mentioned as an 02 Express Van.
    PM me your E-Mail address and I will send you the wiring file.
    Jeff
  1. Need Help 0411 PCM
    By rsicard in forum General (Petrol, Gas, Ethanol)
    Last Post: February 19th, 2010, 09:00 AM
  2. 0411 pcm wiring??
    By onegonewild in forum Gen III V8 Specific
    Last Post: August 18th, 2008, 01:54 PM
  3. 7.5.1 can not find RR
    By mr.prick in forum RoadRunner Real-Time PCM Emulator
    Last Post: December 29th, 2007, 02:46 AM
  4. Help...can't find value.
    Last Post: June 28th, 2005, 03:34 PM
