Results 1 to 9 of 9
Thread: dynoed Nova, look at my log
Hybrid View
    May 2007
    Default dynoed Nova, look at my log
    I dynoed to see where my converter was flashing to. On the data log dashpad b (graph) it looks like 3200 if we start the dyno early or 4200 if we start it at 3000.
    if you look at the dash where the tach flashes it jumps from 2700 to 4600. It is a 8" converter , I would like it to be around 5400 or so per 3 different converter company recommendations. I am just seeing how close I am before I buy another one or get this one restalled.
    With 31x13x15 slicks at 11.5 psi I made 357rwhp on the tune I made from track testing. we tried 2 deg more timing and it did not make as much power. we tried adding fuel but it lost again. my wide band would show around 12.6 where the dyno wide band stayed a steady 13/1 across the board. I could not look better .
    After finding a flat on one side after lunch we aired them up to 15psi and the power went up to 389 rwhp.
    last dyno log was the 389 pull but I forgot to turn my wide band on.
    dyno log 2 has air fuel when we tried more timing and fuel together. I had the wide band on then.
    what do you pros think its flashing too?
    2000 NBM trans am.
    427 Dart ship block,Lme ported Ls7 heads 12.5 compression
    246/262 .730/.712 112+4 low lash solid roller
    Rmvb 4l80 with transbrake, 8" FTI converter
    12 bolt Moser rear end with 4.10 gears
    AS, I'll look when I get on my WIndows PC.
    Wow, 3.5 psi from tire cost 32 hp...
    I saw your vid at HC... tire did wrinkle.
    May 2007
    I just got through swaping the tires out and putting 29x12x15 hoosiers . I hope they do a little better, will try some drag radials next untill Ifind what works best on the car. just trying the tires before restalling the converter.
    2000 NBM trans am.
    Mar 2007
    What brand were the first slicks?
    Hoosiers are great.
    If the Hoosier don't work for ya, try M & H tire. http://www.mandhtires.com/
    M and H will be my race tires for my twin turbo project. They offer lots of sizes (oddball huge stuff too) in both heighth and width.
    May 2007
    I had Mickey Thompson's . I hope the Hoosiers work good, I like the way they look . car has a nice stance with them. I was looking at the m&h's , they have big drag radials I was looking at. just proud of them though.
    2000 NBM trans am.
    May 2007
    Can you guys look at the log and tell me what the converter is flashing to in your opinion? Like I said , on the graph the next frame after full throttle is 4200 but if you look at the dashboard with the tach, it goes to 4600 on the same frame as the 100% throttle.
    Just trying to figure out what I need to tell my converter company. Thanks, Chad.
    2000 NBM trans am.
    Looks to me to be flashing to 4500-4800.
    May 2007
    are you looking at the dashboard or the graphs? I agree with you based off of the dashboard.
    I may see how it 60 fts now with the 29x12 Hoosiers. Then do the converter if it needs it.
    2000 NBM trans am.
    I'm looking at the rpm chart... when rpm starts turning and leveling out... see cursor in attached pic.
  1. 02 sensor locaion for my ls turbo nova
    By 73 Nova Guy in forum Gen IV V8 Specific
    Last Post: November 26th, 2009, 03:59 AM
  2. Dynoed today
    By Kurtomac in forum Gen III V8 Specific
    Last Post: October 14th, 2008, 04:23 AM
  3. Need a tuning expert in NOVA or a REAL tuner
    By NASABlue in forum General (Petrol, Gas, Ethanol)
    Last Post: June 17th, 2008, 09:46 AM
  4. tuning ls1 nova track car
    By speedyblue in forum Gen III V8 Specific
    Last Post: April 30th, 2008, 01:06 PM
  5. Idle issue-67 Nova
    By xtreme in forum General (Petrol, Gas, Ethanol)
    Last Post: May 16th, 2006, 10:36 AM
