Results 1 to 6 of 6
Thread: Engine cranks, won't start. - help
Hybrid View
    Mar 2009
    Default Engine cranks, won't start. - help
    2004 GTO LS1, Auto - Hybrid install.
    Local shop removed emissions, VATS, etc. Had engine running a couple of weeks. Purchased EFI Live, changed fan on/off temps - worked great. Tried to start engine 3-4 days later - cranks, but won't start?? I have 58 psi at the rails, power to the coils, injectors, cam and crank sensors. The scan tool shows 100-200rpm while cranking. Double checked that the anti-theft is off.
    Although I have power to coils/injectors, I have no spark and the injectors aren't pulsing. I checked the plugs by holding them to the frame and put an LED into the injector connectors - nothing.
    New to tuning software.. anything to look for in the software to help diagnose the problem? Unfortunately, I cleared all the DTCs without looking at each one.
    Apr 2009
    does it try to start ? or not at all ?
    Mar 2009
    Not at all.
    Apr 2009
    have you tried another pcm in the car to see if it will start ?? possible dead coils ??
    Also, check:
    - fuses blown,
    - ground connections for voltage drop.
    Apr 2009
    Also, check:
    - fuses blown,
    esp check the relay/fuse for your coils
  1. Replies: 21
    Last Post: January 9th, 2010, 12:27 PM
  2. Cold start perfect, Warm start flares high
    By samh_08 in forum Gen III V8 Specific
    Last Post: May 12th, 2009, 09:36 PM
  3. Cold start great but warm start sucks."Idle
    By mvvette97 in forum Gen III V8 Specific
    Last Post: October 26th, 2008, 12:22 AM
  4. No Engine start on AutoVE.
    By curtbriggs in forum General (Petrol, Gas, Ethanol)
    Last Post: November 25th, 2005, 03:34 PM
