Results 1 to 10 of 15
Thread: Pedal position vs. commanded TAC position weirdness
Hybrid View
    Dec 2008
    Default Pedal position vs. commanded TAC position weirdness
    Has anyone logged actual pedal position vs. actual throttle position enough to notice anything weird on these E38's? I've been trying to figure out why the correlation between pedal and throttle vary between two distinctly different modes. Most of the time the throttle will open ahead of the actual pedal position, which makes acceleration feel stronger since your foot isn't pushing down more, but the throttle is still opening more. Stock trucks do this normally. (I'm talking about E38's in 5.3, 6.0 and 6.2 trucks and SUV's.)
    The other mode, which seems to come and go at random times, is that the throttle will stay tracking pedal position, without the throttle opening faster and more than the actual pedal movement. When it goes into this mode (I call it low throttle mode) it will stay that way all day. It almost always goes back to normal the next day. It might not do it again for a few weeks. It has nothing to do with the actual tune, it will switch back and forth between these two modes on the same tune. (Meaning it's not something I change in a tune, it goes back and forth in between tune changes.)
    My guess is there are some parameters that we don't have access to that affect the relationship between pedal position and throttle position. I wish I could figure this out, there is a huge difference in the feel of the power when it's in this "low throttle" mode. I can tell it's doing it as soon as I start driving, it just feels a little "flat" compared to when the throttle is advancing ahead of the pedal. I believe what I'm trying to describe is the equivalent of the throttle cracker and follower in the older LS1's?
    Thanks guys, hopefully someone has seen this. If I get a chance later I'll try to post up a screen shot of the logs that show the difference.
    Dec 2008
    Here's the screen shots...
    I'm betting the only guys that even noticed this on other E38 are the ones that have a lot of logs with pedal position and TPS (either commanded or actual, doesn't matter) logged.
    The interesting thing here is that if you're trying to tune or assess changes and this happens you'd think whatever change you made lost power, when actually it had nothing to do with what you changed in the tune. Have any of you truck owners ever started driving one day and thought "Hmm, this thing just doesn't seem as strong today", but not enough to make you really think something is wrong? Anyone tuning a car or truck with ETC (throttle, not traction) should be logging these two pids so you can really see what's happening between your foot and the throttle.
    Here's a couple screen shots of what's happening, hope they're big enough to see, I didn't want to make the images huge but I might have to if it's too hard to see. All you have to do is look at ACC (pedal position) and TAC (commanded throttle position) and you'll see what I'm talking about. Normally you'll see something like the 23% pedal position resulting in 38% throttle position, this is what a stock tune would even look like. In this "low throttle" mode, you won't get the throttle advancing farther than the pedal, actually it's behind pedal movement if you take into account the fact the throttle doesn't go to zero like the pedal percentage does. In the "low throttle" jpeg (bottom image) the ACC is at 38% and the TAC is also at around 38%. This results in kind of a slightly "dead" power feel, even though you've done nothing to actually change the power, it's just how much more the throttle is opening ahead of pedal position.
    Obviously if this can be figured out, or if someone already has the answers to this, wouldn't it be awesome to actually be able to change the mapping of pedal vs. throttle? All I want is to keep my truck from going into this "low throttle" mode.
    Thanks guys, sorry for the long post.
    Aug 2008
    This is interesting, I've felt that about my truck also. Sometimes little pedal movement gets my truck going & other days I really have to get on the throttle to get it to move (like it lost power) The craziest thing I notice is how after a cal only flash it feels really good & strong but the next day It goes into that "low throttle" mode, like you're referring to.
    I always thought it had something to do with a Torque Management table that I haven't tried messing with yet...
    I have never logged that TAC Pid...
    FLASHSCAN V2 & AUTOCAL
    swingtan
    Guest
    Looks somewhat like "throttle Follower" to me. In the second image, it appears that the pedal / throttle is much more stable than the first. It is possible that in the second, you have gone over the setting in B1604 ans follower has been disabled. It may be worth logging air flow at the same time to see if there is any difference there.
    Dec 2008
    [QUOTE] The craziest thing I notice is how after a cal only flash it feels really good & strong but the next day It goes into that "low throttle" mode, like you're referring to./QUOTE]
    Yes! That is definitely one of the clues, I've also noticed that after flashing a tune, no matter what the change is, it always runs in the mode that makes the throttle advance ahead of the pedal, making it seem stronger. And yes, it will change all by itself even though you're still running on the same tune. That led me to believe it has something to do with throttle learn, and simply doing a reflash resets the learn somehow. I've also noticed that it seems to have to do with how the first cold start of the day is. If the idle is too high or too low it will effect what this "follower" does for the rest of the day. I've even thought it might have something to do with whether I jump in and go, or let it warm up for a while before starting to drive. There has to be some modifier tables or throttle learn parameters that we don't have access to that control this.
    Gameover you have the same truck as I do, log that pid and see what it looks like. Log TAC_PCT and APP. If you put the APP scale at 0 to 100% and the TAC_PCT scale at 8 to 100% it will be really easy to see when it switches modes. If the TAC_PCT lines are above APP, it's in the "normal" mode, if the TAC_PCT lines are below the APP, it's in the "low throttle" mode. I set my TAC scale that way (the bottom of the scale starting at 8%) because anything below 8% is pretty much idle.
    Dec 2008
    Swingtan, B1604 in my tune is lower than stock (stock is 31.999), it's been that way for quite awhile. It seemed to me that B1604 had more effect on decel than accel, I had success lowering it to get the coastdown rpms to drop faster (like lessening the dashpot on a carb). Good point on going over maximums (or under minimums), sometimes these tables have hidden max values that if you go over them they don't work anymore. Oh yeah, those two screen shots are from the same tunes, I didn't do any reflashing in between.
    I have noticed that you can create the same effect by playing around with B1650-Max ETC Area. If you go lower on the numbers, it makes the throttle open ahead of pedal movement since it thinks you have a smaller throttle body than stock. Opposite also has the effect of making the throttle follow pedal movement closer, since it thinks you have a huge throttle body and small movements would make bigger airflow changes.
    I don't think either of these tables are the answer though, putting the settings higher or lower than stock don't seem to have an effect on this random "low throttle" mode.
    Thanks guys.
    Oct 2005
    Adaptive Abuse Management?
    2014 VF SV LS3 Maloo.
    Dec 2008
    Anybody figure anything out on this?
    Dec 2008
    Anyone find anything on this or see what I'm talking about? It seems to me that this has to do with the throttle/idle learn that the E38's do on startup. If you do a cold start up and start driving right away it won't run the idle learn, which most times will leave the relationship between pedal and throttle in the higher mode. If you do a cold start up and let it idle for a few minutes before driving, it will learn the pedal/throttle relationship lower and the throttle will not track ahead of the pedal movement.
    Ross, Paul, Joecar, have you guys looked or have you seen any other tables in the E38's that have to do with throttle or idle learn? It also seems like it has to do with the computer seeing more airflow at a certain throttle position that it likes so it just scales back the relationship between pedal and throttle. I know there are DTC's that will set if it gets too far out of range, but I think it's also reducing throttle opening slightly to try to keep airflow/tps/pedal position in what it thinks is the right range.
    So many guys are just looking at full throttle power, which this does not effect, I wonder how many are adding throttle response and power with their add-ons only to have the computer take it away?
    Dec 2008
    Hello? Anyone out there? 4 months and not a word from any EFILive guys on this?
    I own and use both EFI and HPTuners, I hands down believe EFI hardware, software and BBL is WAY better than HPT, but come on guys, at least the competition is trying to help me figure this one out.
    Supposedly there are tables that control pedal to throttle mapping, and PID's that show what modes the throttle curves are in. (There are 4 or 5 throttle modes, I just have no way of knowing why it's changing modes or what mode it's changing to.) This does have to do with idle/throttle learn, if I reset idle learn with the scanner or a Tech 2 it will go back to the higher throttle mapping every time. I just can't get it to stay there consistently. (Obviously "idle learn" does more than just the idle.) If all we got was a couple PID's that showed anything about idle/throttle learn, that might help. Or any tables or on/off settings that control when it does the idle learn. Anything. Please.
  1. EGR position
    By maxxflip in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: December 7th, 2009, 04:30 PM
  2. Q on O2 Wires, and MAF Position
    By Dale in forum General (Petrol, Gas, Ethanol)
    Last Post: May 7th, 2008, 12:29 AM
  3. where to get a 5 position switch
    By 69camaro5speed in forum Duramax LLY
    Last Post: April 6th, 2008, 12:17 PM
  4. Throttle position 256%
    By vatman02 in forum General
    Last Post: September 27th, 2007, 06:08 PM
  5. 5 position switch
    By Rambo in forum Duramax LB7
    Last Post: February 15th, 2007, 08:14 AM
