Results 1 to 8 of 8
Thread: changed tire size, now ABS INOP
    Dec 2006
    Default changed tire size, now ABS INOP
    I changed my rear tire size to a 295/50R16 (mickey thompson) on my 02 TA. (which looks sweet by the way). But now the ABS INOP, Brake and TCS off light is on. The brake feel like they are working fine. I few read this issuse is doen the different size in tires on front to back, give the ABS system a bad signal and trips it off which then trips the TCS. My question is "Is there way to tune for the bigger tires in the back and still keep the ABS working?" I did the speedo cal to fix the speedo.
    Aug 2007
    you could try upping the tire size in the abs module, this is done with a tech 2 from gm, if it is possible on a 02 ta, I have done it on my 05 silverado. That may or may not fix the issue, I haven't tried it for that setup, I had to do it on a customers 02 silverado to get rid of the abs light for his 35" tires, I upped it to the max of 285/75/16's seemed to work in his setup.
    2005 chevy silverado, duramax tuned with efilive
    1997 Saturn sc2 turbo, tuned with megasquirt on e85
    2000 s-10 turbo'd tuned with efilive on e85
    Dec 2006
    thanks i'll give it a shot
    Feb 2006
    Did the ABS INOP, Brake and TCS off lights come on before you corrected the speedometer settings with EFI_Live? F-body's with traction control have the rear ABS wheel speed sensors at the axle, not the ring gear. EFI_Live does not adjust for different tire sizes for these vehicles. The ABS/Traction Control will not work properly unless the tires are within specification.
    Al
    Dec 2006
    all three lights came on before and after the speedo cal. Understand I wont have ABS or TCS with these tire's installed. Will pulling the ABS fuse stop the lights for coming on? Im just worried about abs trying to work some times and causing a driving problem. Or should I just live with the lights?
    Aug 2007
    when abs lights are on, system is locked out from operating. Another possiblity to elimanate the lights is cut the rear sensors and the rear inputs on the abs brain tie those inputs to the front sensors, not sure how well that will work or if it will work at all. Only isssue with that is abs system will not know if the rear tires are skidding.
    Aug 2008
    Quote Originally Posted by gcross View Post
    If you check the trouble codes you will probably find that you have mismatched vehicle speed between the front and rear wheel speeds in the ABS module. Since the front sensors go to the ABS module and the rear sensor goes to the PCM, the calibration must be correct for tire size in order to allow both calculations to be correct so that you have the right amount of pulses per mile. The tire size is adjustable in the ABS using the Tech 2, but you can only choose from factory options. Since you didn't change the tire size in the front, you must change the calculation that outputs the VSS signal that the ABS uses. Try looking at H104 (I think). Not sure of the location, but that is what you need to fix.
    There are either 4 or 5 speed sensors on the vehicle:
    a. 2 at front (1 at each front wheel),
    b. 2 at rear (1 at each rear wheel) or just 1 on the axle ring gear;
    c. 1 at the transmission output (or axle shaft on Corvette);
    The ABS/EBCM (brake controller) module sees a. and b.
    If the rear sensors don't agree with the front sensors, then the ABS/EBCM module will throw DTC's.
    The PCM/TCM sees c.
    This is what the PCM/TCM uses to lookup shift tables and also transmits it to the IPC.
    EFILive can program c. via the H0101 and H0104, but you need another tool (Tech 2) to program b.
  1. How to change tire size on LL8?
    By dirt_track_racer_81 in forum LL8 4.2L In-Line 6 - P10 PCM
    Last Post: October 29th, 2010, 06:55 AM
  2. Adjusting for tire size on an 01 2500hd
    By FTK_Ray in forum General (Petrol, Gas, Ethanol)
    Last Post: May 7th, 2009, 04:03 AM
  3. help changing tire size!!!!
    By 2007silverado in forum General (Petrol, Gas, Ethanol)
    Last Post: June 2nd, 2008, 06:21 AM
  4. Adjust for tire size
    By Boost in forum General (Diesel)
    Last Post: March 29th, 2007, 11:32 PM
  5. LBZ tire size change
    By BigTex in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: January 12th, 2007, 03:14 AM
