I have tuned several of these using the lastest build 88. This is the 1st time this has come up.
Here is the file.
Here is the file.
This is supported in the latest pre-release version available here: http://forum.efilive.com/showthread.php?t=12834
Please download both eh version V7.5 and V8 products and ensure you update the firmware on your V2 to 2.06.24.
Andrew
EFILive Crew
So I have the new update in it now. How do I update the flash scan. I have been reading the how to and I still cant figure it out.
Have a look i the 'C:\Program Files\EFILive\V8\Documents\Upgrading FlashScan.pdf' document, especially if you are still running firmware version 2.04.x.
Otherwise you should pretty much be able to connect V2 and open EFILive Explorer. This will start the EFILive_Hapi application which shows in the taskbar (icon that looks like a V2 device). After a few seconds this should prompt you to update automatically.
Andrew
EFILive Crew
Thanks.
Everything is working great now.
