Results 1 to 7 of 7
Thread: +50% STFT bank 1 during idle only??
    Lifetime Member samh_08's Avatar
    Oct 2008
    Default +50% STFT bank 1 during idle only??
    As the title says. What would cause such a thing? Poor performing o2 heater on that bank is the only thing I can think of.
    All bank 1 injectors are firing as well as spark to all of them.
    Jul 2008
    Other than a massive exhaust leak.
    Is it only at Idle?
    Oct 2008
    Yes, it is only at idle. Once I get on the gas both of the banks are the same as each other.
    Like Shawn said check for air leaks.
    Then, swap O2 sensors across banks.
    Then, swap injectors across banks.
    Oct 2008
    Sounds good Joe. Is there a way to test the o2 sensor heaters? I really feel like this is the issue..
    Feb 2006
    Turn the key on engine off, both front O2's should swing from bias voltage to a lean value in about the same time. If the heater is working then the O2 sensor voltage should change.
    Al
    Jul 2007
    Here's an example of what happens when O2's play up. In this example I was doing some WOT tuning so was not really concerned with O2's and trimming. I used a std. PID selection that just happened to include the STFT's but had no intention of using them. the car did not have a dedicated WB O2 port in the exhaust, I just removed a NB and tied it up out of the way. As the tune would check the O2's for operation, this would force the tune into OL mode, as the O2 would always be reading fresh air.
    The tuning went well, but every so often when coming to a stop, the WB showed that idle mixtures were progressively getting richer, but not all the time. I enabled the display of the STFT's to see that they were adding fuel. Here's a pic of the log file...
    What I believe is occurring, is that the O2's were being enabled, but only when idling and not all the time. Because one O2 was reading freash air, the PCM was adding fuel to try and richen things up. The NB O2 never indicated that the additional fuel was being effective, so the PCM kept adding fuel. This is seen in the WB O2 data. In this log, trim s got to about 15% before the PCM realised the O2 for bank 1 was "faulty" then it dropped to OL mode. The funny thing was that it would switch back to CL at times.
    There was nothing really wrong with the tune or the O2's in this case, as one was not in the exhaust stream. Once it was returned to its normal position, All was good again.
    Simon.
    Holden VZ SS 6Lt L76 M6, 220/224 @114, 0-100kmh < 5 seconds
  1. Bank 1 to Bank 2 Injector Pulse time
    By BRD-PREY in forum Gen III V8 Specific
    Last Post: June 10th, 2010, 06:33 AM
  2. Ignition timing issue,bank to bank
    By AllOutPerformance in forum Gen III V8 Specific
    Last Post: December 5th, 2009, 12:38 PM
  3. STFT Idle
    By Mort in forum Custom Operating Systems
    Last Post: October 17th, 2009, 02:46 AM
  4. bank to bank variance in open loop!?
    By ringram in forum General (Petrol, Gas, Ethanol)
    Last Post: July 21st, 2006, 04:38 AM
  5. How much can LTFT's vary between bank 1 and bank 2?
    By vettenuts in forum General (Petrol, Gas, Ethanol)
    Last Post: July 12th, 2006, 11:47 PM
