Results 1 to 10 of 11
Thread: Can't flash
Hybrid View
    Jan 2007
    Default Can't flash
    I can't get efilive V1 to detect the ecm or tcm when I try to reflash. Now that I think about it the last thing I changed on the tune was I disabled VATS. So maybe thats the problem. The truck will run and start fine no codes but I can't reflash. Anyone have any ideas? I also have a ipod adapter that always causes problems over the bus but I can reflash once I disconnect but I have flashed plenty of times before and never had problems with the adapter?
    Jan 2007
    How would the vats being disabled not allow the ecm or tcm to communicate?
    I tried pulling all the radio fuses to make sure it wasnt the ipod interface but it still dint work?
    Jan 2006
    what message are you getting?
    Custom Tuning Services
    Jan 2007
    I get no communication at all. It will get to where it says detecting ecm and tcm then it says they are not detected, then it tries to get status 10 times and then gives me the error cannot connect with ecm check connection then status unknown. im pretty sure this hapoend after I disabled vats but the reason I disabled it was because the engine was idling one time and it just cut off and said battery not charging I can't remember the code but I think it was a moduel communication error.
    Jan 2006
    don't be offended.
    is the ignition on (not accessory)?
    Can you read the ECM? If not, check the fuses by the battery. I can't remember what it is labeled, but it controls power to the obd port.
    Jan 2007
    Yeah Ive got it on. That seems like a really good idea becuase im getting no led lights from the V1 box.
    May seem stupid, but what ECM/TCM do you have? If you have an LBZ or LMM, a V1 will give you error messages as it cannot communicate with either controller. V1 does not support the CAN message bus.
    Jan 2006
    He posted in the LLY forum
    Quote Originally Posted by killerbee View Post
    Didnt even pay attention to that, Im in the habit of clicking new posts and not looking through the actual forums anymore.
    Jan 2007
    Ok I got it it was the cig. lighter fuse thanks for the help, but I wonder what cause it.
  1. did i flash or not
    By Eric in forum Gen III V8 Specific
    Last Post: March 30th, 2010, 06:18 AM
  2. Pre Full Flash to Full Flash Tune Question
    By Donovan in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: January 13th, 2010, 12:43 PM
  3. OS Flash
    By L31Sleeper in forum General (Petrol, Gas, Ethanol)
    Last Post: August 25th, 2009, 02:15 PM
  4. No Flash!
    By horsehaulin in forum Duramax LB7
    Last Post: May 31st, 2008, 04:22 PM
  5. Can i flash my VIN in a used PCM?
    By mvvette97 in forum Gen III V8 Specific
    Last Post: September 18th, 2007, 12:23 AM
