Results 1 to 10 of 10
Thread: Boost timming AFR ??? GT4294 on stock LS1
Hybrid View
    Jan 2008
    Default Boost timming AFR ??? GT4294 on stock LS1
    All
    finally have my car on the road.
    Details:
    intercooled, single GT4294
    60Lb injectors
    10Lb Boost
    11.5 AFR
    11 Degrees timming at WOT
    what timming, boost and air fuel ratio's have people had on a stock LS1
    single 044 fuel pump will be coming soon
    VX Commodore Turbo Intercooled - GT4294 - 60lB injectors - 3K stall
    Oct 2006
    When you say stock engine have you done valve springs? we have had issues with boost and STD valve springs.
    Jan 2008
    no, havent done valve springs.
    dont seem to have a problem there.
    hasnt been on the dyno as yet but goes to 5500rpm no problems
    also: has anyone put the IAT sensor in the intake pipe, will it handle boost?
    my idea was to put it just before the throttle body
    Aug 2006
    Hi, most kits normally as the IAT in the intake pipe. regards Jason
    Oct 2006
    You may have issues with your valve springs on the dyno under heavy load, most of the turbo setups we have done if not all them have had valve spring issues with standard springs.
    We normally buy a new IAT sensor with BSP tread and weld on a thicker plate to the intake just before the throttle body and tap it out, earlier Holden 5L sensors work well.
    On a standard engine with a turbo of that size we wouldn’t often go over 10psi, if we do the customer knows that they are starting to move away from a safer area into you may have issues, we have a few running boost controllers to lift the boost to 12-14 psi for short bursts or the drags.
    We normally aim for around 11.8 AFR and timing around 10-16degs, our fuel over here is pretty poor so you should get at least that into it especially with the good size turbo you have.
    Jan 2008
    Thanks for the info
    i will try to adapt the factory sensor to a weldable bung or something
    as for the valve springs, i guess we will find out when it goes on the dyno.
    currently, the exhaust runs:
    3.5 inch dump pipe, plits into two 2.5, joins then splits into two again. horrible
    i have a feeling this is killing power. i will be soon making it a single 3.5 inch to tip
    Any thoughts power wise?
    Jul 2008
    Fezz valve springs are a good idea. They are certainly a weak point of the engine and lets face if for a small outlay might save having to rebuild or replace the motor later.
    I have a supercharged (Vortech) LS1 and have the IAT in the intake about 150mm from the throttle body, best place for it, but try and insulate it from engine bay temps, worked for me by reducing the temps slightly.
    Junior Member Frost's Avatar
    Nov 2009
    I had a somewhat stubborn customer that wanted to "just see" about valve springs and lost his engine on the street about 2 weeks after putting everything on the car. Parts went through the turbo and killed it too.
    Steve Williams
    Lifetime Member johnv's Avatar
    Jan 2005
    Quote Originally Posted by Frost View Post
    ouch !!
    get some patriot gold valve springs $255 US, cheap insurance
    Back yard boost
    347+ T76 = 770 rwhp 10.96 @ 135 mph
    Jan 2008
    probably a good idea.
    might save the next post being a bad one.
  1. 40 Degrees max timming, i want more
    By fezz57 in forum Gen III V8 Specific
    Last Post: November 5th, 2011, 08:36 PM
  2. Shift timming
    By bdr2008 in forum Allison 5 & 6 Speed
    Last Post: February 17th, 2009, 02:19 AM
  3. Question about Pilot timming for LBZ...
    By epb091786 in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: April 14th, 2008, 12:47 AM
  4. Duramax timming
    By Rambo in forum Duramax LB7
    Last Post: April 7th, 2007, 08:23 PM
  5. retard timming for N.O.S. help please
    By RandyWS6 in forum General (Petrol, Gas, Ethanol)
    Last Post: March 9th, 2005, 06:52 AM
