Results 21 to 30 of 35
Thread: Where is all my timing going??? Log attached
  1. #21
    I have heard of rich knock, but I don't know how/what/when.
  2. #22
    It's also possible to get a rich misfire, is that your stumble...? Wideband would show lean during a misfire.
  3. #23
    Oct 2006
    Yep, keep safe...!!!
    X2.
    I did some acceleration tests on our track (1/4 mile) monday night. Even in dry conditions with roll on starts the wall came into view more times than I would like to repeat. I wont be doing any more testing on street tyres from now on. (not if I want to keep driving the car to work in one piece)
    When you are able to do some more logging exploder post them up & we will see if we can spot anything helpful.
    The Tremor at AIR
  4. #24
    Senior Member exploder's Avatar
    Aug 2008
    I went and made a few logs today and I think I got the AFR settled, and the timing doesn't just fall off now that I zeroed out the burst knock tables.
    The problem now is even with the AF in the semi correct range I still have this horrible hesitation. It almost seems like it wont pull through it. I never get any knock retard on the scanner though. I gapped the plugs at around .035. I don't know if it's possible that I may have fouled the plugs, but wouldn't it run like crap all the time? It seems to run pretty good just normal driving around. As soon as you roll into boost and it hits around 5-7psi it starts spitting and sputtering like crazy and it will hardly accelerate. HELP
    Here is the log and a new tune. Are my knock tables stock?
    03 z06 auto
    ver7.5.5 custom OS5
    415 ci
    239/255 .624 lift LSr grind
    16psi
    Meth injection
    PLX WB02
  5. #25
    Aug 2008
    I think I may have found the problem. I asked my employee what plugs he put in the car and he told me tr6, but he hesitated when he told me. Anytime sombody hesitates when you ask a direct question is more than likely lying. I told him to go pull one off and let me look at it. I ended up watching him through the window and you should have seen his face when he turned around and saw me watching him. They ended up being TR55 not TR6 and they were also gapped at .045. I don't know what he was thinking, but I get to take it all back apart and hes not getting paid. I will report back when I get it all back together, but on a side note the plugs look GREAT. I will be wearing a sad face all weekend thinking about this.
    03 z06 auto
    ver7.5.5 custom OS5
    415 ci
    16psi
    Meth injection
    PLX WB02
  6. #26
    The spark might be blowing out under load...?
    Post a close up pic of plug if you can.
    What coils and wires are being used...?
  7. #27
    Jul 2008
    O.K., guys I will ask the 'dumb' question. With the OP's SC application and COS5..is there no MAF?
    I don't see a DTC..but if it is not physically there..
    Just trying to learn..
    Thanks..
  8. #28
    Aug 2008
    I am running no maf at all only a IAT and MAP. I have a P0102 code when I check the codes through the instrument panel cluster through the car but the light is not on the dash. Is that wrong?
    03 z06 auto
    ver7.5.5 custom OS5
    415 ci
    16psi
    Meth injection
    PLX WB02
  9. #29
    Jul 2008
    If you don't get a MAF DTC then it will still run from the MAF... set P0101,2,3 in C6001 to 1-Trip.
    I was just going by your posted log..(See attachment). It says NO DTC. The only way a car can run SD is with a the MAF Faulted (DTC). I don't know whether your Scan Tool is set to erase existing DTC's or not?
    Lately, we have seen a half-dozen or so tunes posted (with problems) where tuners who think they are running SD or in reality not. In most cases the Engine DTC Processing Enablers C6001 are set improperly (to not report).
    It becomes very difficult to know if one has indeed faulted the MAF. In most cases tuners copy the Low-Octane Spark to read exactly what High-Octane Spark indicates (remember in MAF Failure PCM uses Low-Octane Spark Table). So it becomes hard to see if indeed the MAF has failed.
    Think how a car will run if one thinks the MAF is failed, but in reality it is not? Personally, I am not 100% sure how setting C6001 to Non-Emissions affects the DTC Code. I am just relaying what quite a few have posted in the last few months. Thats why I always set C6001 to 1 Trip, Emissions Related when I utilize SD. It always then shows up as a DTC. Call it overkill, but I set C6002 to MIL. Its a good check.
    One thing seems for sure. You can not run SD without failing the MAF. That is whether it is physically present or not. I do not know if this perfectly describes your situation, but something to highly consider.
    Good luck..
  10. #30
    Oct 2006
    Shawn, when BBl I never get the p0102 code showing in the log. I have just put it down to using this method of logging as it is definately failed in my tune.
    The Tremor at AIR
  1. help with p0101 code, tune file attached
    By adam1803 in forum Gen III V8 Specific
    Last Post: May 25th, 2009, 12:05 PM
  2. Truck dies randomly, screen shot attached
    By thunder550 in forum General (Petrol, Gas, Ethanol)
    Last Post: September 11th, 2008, 03:08 PM
  3. BIG Auto VE problem - Tune files attached
    Last Post: October 14th, 2007, 02:57 PM
  4. o2 sensor switching question (log attached)
    By brentg454 in forum Gen III V8 Specific
    Last Post: April 6th, 2007, 01:19 PM
  5. Can't increase timing while brake stalling (tune and log attached)
    By thunder550 in forum Gen III V8 Specific
    Last Post: January 18th, 2007, 04:44 AM
