97Vette using v7.4 I have the pids selected for AutoVE but cannot validate them. All items under the 'Info' menu are grayed out. Is my V1 flashscan defective?
The 7.4 version is now very old and no longer supported. Please update to the latest release from our website: http://www.efilive.com/index.php?opt...=48&Itemid=133
Or install the latest pre-release from here: http://forum.efilive.com/showthread.php?t=12014
Before installing the latest software please uninstall the current 7.4 release. Backup up the 'C:\Program Files\EFILive' and 'My Documents\EFILive' folders before hand in case there is anything you wish to keep.
Andrew
EFILive Crew
2005 HSV Maloo Ute, HKE 457ci Stroker LS2 E40, TFS 245's, 255/263 Hi Lift HUC, FAST LSXr 102, NW Billet 102 TB, FLT Level 7 4L65E, CircleD 4200 stall, Duspeed OTRCAI - Mafless, DF 1 7/8" LT's, 3" DiFilipo Duals, Serial LC-1 WB's
"An Old Dog learning new tricks"
Make sure the VIN is valid. EFILive uses the VIN (the first 2 characters) to determine if it should load the manufacturer's enhanced PIDs or not.
Really, you just need to make sure the VIN has the first 2 digits of 1G, the rest is ignored by efilive for gas vehicles.
If you're not currently connected, you can set the VIN used by EFILive with the menu option: File->Enter VIN.
If the VIN in the vehicle is missing or wrong, you can change it using the menu option: Bidirectional->Change VIN.
Had yellow exclamation mark on the usb in the device manager, reinstalled device driver as well as v7.5. Scan tool working again.
current v7.5.6 build 112. The tune tool shows operating system as 19970200, but that op system is not in the drop down list in the scan tool under the 'enter vin' menu.
Can't validate these pids:
GM.IAC_LTD_DMA
GM.IAC_STD_DMA
GM.CYLAIR_DMA
GM.DYNCYLAIR_DMA
Trying RAFIG:
Log_0029.efi
SDAutoVE_0009.tun
Help - Need some pointers on leaning out idle AFR
The 1997/8 OS's might not have all the _DMA pids defined.
These pids
GM.IAC_LTD_DMA
GM.IAC_STD_DMA
GM.CYLAIR_DMA
GM.DYNCYLAIR_DMA
have red x's thru them in pid list, but do have values recorded in log. See the screenshot in post #8.
