Results 1 to 9 of 9
Thread: New V2 help find exlporer
    Jul 2009
    Default New V2 help find exlporer
    I've seen the thread on how to upgrade the firmware on the V2, but how do I tell which firmware I'm running and where the latest firmware dl is?
    Also I have Flashscan Firmware Programmer, when trying to check status of my V2 gives the error:
    The attached device has previously been upgraded to bootblock v2.05.xx or greater. "Flashscan Programmer" can only be used w/ v2.04.xx or less. Please use "Efi Explorer" program.
    I've tried searching but can't find any links to said Explorer program, am I missing something?
    Thanks for your time
    -Jerry(noob)
    Hi Jerry,
    Download/install V7.5.6.117 and V8.1.2.97 from here: Software-Updates-and-Installation-Help
    Then start EFILive Explorer (EE), goto Firmware tab, this will show the bootblock/firmware versions... post what they say.
    Edit: V7 and V8 versions have been bumped up... load the latest.
    Jul 2009
    My Scan tool version says its 7.5.6 build 117, i just don't see this EE
    Do I need the 8 version also?
    Yes, EE and S&T comes with V8.
    EE is used for:
    - flashing bootblock/firmware into V2,
    - formatting the Config space on V2,
    - setting V2 splash screen and date/time,
    - retrieving BBL and BBR files,
    - uploading BBW (.ctd) files.
    S&T is used for:
    - setting/programming V2 options,
    - creating/setting/programming V2 BBL pids/pidlists,
    - creating/setting/programming V2 BBR/BBW modules (PCM, ECM, TCM).
    Jul 2009
    Thanks for your help, I didn't realize I need V8 also.
    Its installed, updated and updated bootblock to 2.06.03 and firmware to 2.06.35
    Be sure to format the Config space (in EE goto Config Data tab and click Format).
    Then exit EE and start S&T to set V2 options and BBL/BBF settings.
Name:	S&T - Device Settings - BBL.png
ID:	8222   Click image for larger version.
Name:	S&T - Device Setings - Serial IO.png
ID:	8227   Click image for larger version.
Name:	S&T - Black Box Settings.png
ID:	8224   Click image for larger version.
Name:	S&T - Black Box Settings - Scan Settings.png
ID:	8226   Click image for larger version.
Name:	S&T - Black Box Settings - Tune Settings.png
    Senior Member MyM8V8's Avatar
    Aug 2008
    Joe, how do you know if the config spac is formatted or not? (Strange question I know)
    2005 HSV Maloo Ute, HKE 457ci Stroker LS2 E40, TFS 245's, 255/263 Hi Lift HUC, FAST LSXr 102, NW Billet 102 TB, FLT Level 7 4L65E, CircleD 4200 stall, Duspeed OTRCAI - Mafless, DF 1 7/8" LT's, 3" DiFilipo Duals, Serial LC-1 WB's
    "An Old Dog learning new tricks"
    Quote Originally Posted by MyM8V8 View Post
    Whenever I update the firmware, I then immediately format the Config space.
    Default What is the difference between V7 and V8...?
    V7 software:
    this is the traditional scantool and tunetool that you use for scanning/logging/reading/flashing with laptop in vehicle;
    scantool is also used for viewing log files; tunetool is also used for editing tune files.
    V8 software:
    this is the Black Box mode configuration tools, S&T and EE (described above), and includes V2 firmware/bootblock.
    S&T is used to configure V2 for BBL/BBR/BBW; EE is used to copy logs and tunes between V2 and laptop;
    V8 software will eventually provide the functionality of the V7 scantool/tunetool.
  1. Who can find the problem?
    By JOHNGEAR in forum Forced Induction and Nitrous Oxide (N20)
    Last Post: December 24th, 2008, 10:24 AM
  2. 7.5.1 can not find RR
    By mr.prick in forum RoadRunner Real-Time PCM Emulator
    Last Post: December 29th, 2007, 02:46 AM
  3. Can't Find dps5 OS
    By spurs442 in forum Duramax LB7
    Last Post: December 10th, 2007, 05:30 AM
  4. Help...can't find value.
    Last Post: June 28th, 2005, 03:34 PM
