Results 1 to 4 of 4
Thread: Valet mode safe for building boost?
    Feb 2005
    Default Valet mode safe for building boost?
    In my search for a better 60 foot time I'm looking for ways to build boost. From the tutorial
    The Valet mode RPM limiting uses fuel cut-off to limit the engine RPM, it does not use spark cut. It is not recommended you hold the engine on the RPM fuel cut for very long as the engine can run lean and damage the engine itself and/or catalytic converters, use it sensibly.
    Is anyone using this to build boost off the line? How long is too long?
    2001 Camaro SS
    EFILive Custom OS3
    Feb 2005
    well I guess tha silence means I get to test it and let everyone kno...
    2001 Camaro SS
    EFILive Custom OS3
    Oct 2005
    Its a switchable RPM limiter which will cut fuel.
    I dont know why you would want to use this on a FI engine, you could run too lean and shower yourself with engine parts.
    I would think if you wanted to use it you would have to make it cut out at very low rpm on FI.
    2014 VF SV LS3 Maloo.
    Feb 2005
    Sorry I don't know everything about two steps but I would expect that if they cut the ignition that would be ok. Cutting the fuel sounded like a disaster to me and I wanted clarification. Guess this is another example that this software was written for people who "know how to tune" and "stupid" questions get avoided.
    2001 Camaro SS
    EFILive Custom OS3
  1. Safe Mode?
    By Grey Silver in forum Gen III V8 Specific
    Last Post: August 27th, 2007, 05:34 PM
  2. Can Valet mode be used to turn SD mode off and on?
    By ForcedC5 in forum General (Petrol, Gas, Ethanol)
    Last Post: May 17th, 2005, 11:53 AM
