Thread: Possible TCC Slip/TCC Tuning?
    Sep 2010
    Default Possible TCC Slip/TCC Tuning?
    We put a 2400 Precision Stall in a 2010 Camaro and I re-tuned the T43 with my typical settings but I am not sure if I am missing something special that has to be done for TC changes such as slip times, etc or if these are even possible to change.
    When cruising at 1/2 or 3/4 throttle around 4000rpm the car seems to shutter almost like the TCC is locking/unlocking.
    Paul Meister
    EFI Calibrator/Managing Member, Torq Speedlab, LLC
    Specializing in late model Ford, GM and Dodge EFI Calibrations
    SCT, EFI Live, HP Tuners, FAST, BS3 and much much more
    Jul 2010
    with my A6 running a 3000rpm converter i only lock it in 6th gear above 70kmph, and also raised my TCC slip by quite a bit... especially in the (-) cells.. This seemed to help a fair bit... What diff ratio are you running? We really need PWM tables in these TCM's
    I also adjusted my "Minimum idle airflow tables" in the ECM around the rpm that it locks, this also seemed to help,(not chugging as much) im running 9's in all cells from 1000rpm for my cam...
    Let me know if u want to have a look at my tune
    Cheers Ryan
    Hi Ryan,
    I'm interested in looking at your TCM tune, please... do you also hack the stock tune...?
    Jul 2010
    Hi Joecar,
    This is my modified tcm tune with 3000 stall & 3.45 gears
    I just used the GTS tune off holdencrazy as a base file..
    Cheers Ryan
    i dont have an issue locking my auto. i run it locked in 4th gear for dyno use and on the road.
    i have some drag racing vids on youtube aswell, where you can here the convertor lock once it's in 4th.
    convertor is a circle'd stage 2 - 3600rpm
    Quote Originally Posted by VEV8 View Post
    Hi Joecar,
    Cheers Ryan
    At holdencrazy I see a 2009 GTS file, I don't see a 2008 GTS file.
  1. T42 4L60e TCC tuning
    By jpgmtech in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: October 1st, 2010, 09:13 AM
  2. TCC Slip when showing fully locked.
    By mhburton in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: February 28th, 2010, 10:14 AM
  3. Vigilante TCC, TCC PWM, lockups, and you
    By arubenstein in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: July 21st, 2008, 03:07 AM
  4. DTC P1870 & TCC slip table
    By tblu92 in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: May 19th, 2007, 01:11 PM
  5. Non TCC PWM transmission/converter in vehicle originally wth TCC PWM?
    By 350SS in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: March 17th, 2007, 07:15 PM
