Results 1 to 10 of 13
Thread: Throttle stops working when accelerating..
Hybrid View
    Jan 2011
    Default Throttle stops working when accelerating..
    Hi,
    For some reason when you try to accelerate quickly the throttle just goes back to idle mode and the pedal no longer does anything, to fix it i have to turn the car off and wait a minute. start it again and the pedal now controls the throttle again. It also does it before you start the engine, if i randomly keep pushing the pedal to the floor the throttle will randomly stop working again. Im running a stock 2008 ve l98 manual ute tune. When I was running a ls3 corvette tune it only did it twice. The only code that I can see that might have something to do with it is. P0606? Is it going into some kind of failsafe mode?
    Jan 2011
    So I connected the scanner to the ecm and ran pids ETCPP1 and ETCTP1 with the ignition on and the engine off, if I slowly push the pedal once they both get to 50 the ETCTP1 drops down to 10% and the throttle no longer responds to pedal movement, but if i push the pedal really fast the throttle works fine. If I push it really fast to 100% and slowing back off ETCP1 drops back down to 10%, I have tried two different throttle bodies. also got code 1516 before.
    Senior Member doubledip's Avatar
    May 2008
    caused by wrong base tune in the ECU
    either running a US Base tune and then have flashed a Holden tune in (no go)
    or
    have a Brass throttle blade and are running a early type ECU/OS
    E38's got to love them
    E40's hate 'em
    LS1's is there anything it wont work on
    Holden VE SSV - GEN46L
    www.ultimateconversionwiring.com.au
    www.dualflash.com.au
    Jan 2011
    Well it is a 2008 ecm, both throttles are the alloy coloured blades, when I actually first connected to the ecu it had no tune on it, is there a way to reflash the ecu back to normal?
    May 2008
    thats your problem.. your cant go flashing into a "blank" ecu a tune via EFILive or HPtuners etc... you need to have your ECU flashed via TECH2 with a base tune . This makes sure all the tables in the ECU are compatible with everything you are using (mainly the throttle tables / throttle body / pedal)
    E40's hate 'em
    Jan 2011
    So off to Holden with the ecu I'm assuming? unless somebody else in Au has a tech2?
    May 2008
    We have a tech2 and tis2web access as well and are in OZ sydney
    E40's hate 'em
    Jan 2011
    How interesting, How shall I contact you, cant msg you...
    May 2008
    msg'd you
    E40's hate 'em
    Jan 2011
    Sorry cant use prvmsg yet, email me, ivile at bur.st , thanks.
  1. E38 - Throttle Cut / Throttle Blip
    By Z06-GT3 in forum Lounge
    Last Post: June 14th, 2011, 04:16 AM
  2. how to tune throttle follower and throttle cracker?
    By z28ls1818 in forum Gen III V8 Specific
    Last Post: September 19th, 2010, 03:43 PM
  3. C.A.S.E not working
    By uaesands in forum E37, E38 & E67 PFI ECM's
    Last Post: September 25th, 2009, 02:38 AM
