Results 1 to 10 of 13
Thread: Knock Sensor DTC ???'s
    Aug 2008
    Question Knock Sensor DTC ???'s
    Stock Camaro T-56 & 2004 5.7 LS1 in a 1993 RX7...
    If knock sensors were not connected(Knock sensor DTC were there) during a 1/4 mile pass...What would LS1 pcm do?
    Would it automatically default to low Octane table? What else? There is no power after 2500 RPM...I'm 99% positive that was culprit for low power...Just after some info...
    FLASHSCAN V2 & AUTOCAL
    Lifetime Member Boost's Avatar
    Dec 2006
    I looked at "action taken" by the PCM for all the knock sensor related codes and did not see any indication that it would reduce power further that defaulting to the low octane table. I assume this is what you mean by "no power". There is quite a drastic difference there so I'm not suprised. Sounds like an easy fix.
    TORQUE SOUTH Tuning 125 VINs programmed
    2013 Buick Verano T 400+ lb-ft tq @ 26 psi with EFILive E39A
    1/8 mile: 8.933 @ 78.6 mph - world's fastest GM Delta platform
    2012 Chevy Cruze LTZ RS 200+ lb-ft torque @ 22 psi with EFILive E78 / T76
    40,000 MILES SO FAR OF RELIABLE AND POWERFUL 30 MPG TUNE
    www.torquesouth.com / www.gmtune.com / www.tstune.com
    Aug 2008
    I agree that it's pretty drastic going from a Tuned High Octane Spark table down to the Low Octane Spark table...but what I want to know is if thats all that happens when Knock sensor DTC's are present...
    Dec 2006
    Yes, that's what I meant. No further action is taken other than a MIL.
    Member ippielb's Avatar
    Jun 2010
    The knock sensor responds to spark knock caused by Pre-detonation of the Air/Fuel mixture. As the flame front moves out from the spark plug ignition point, pressure waves in the chamber crash into the piston or cylinder walls resulting in a sound known as a knock or ping. This is caused by using a fuel with a low octane rating, overheating, or over advanced timing. Sometimes it can be caused by hot carbon deposits on the piston or cylinder head that raise compression. A knock sensor is comprised of Piezoelectric materials; Crystals that when impacted, generate a voltage (same idea as a BBQ ignitor). This voltage is monitored by the computer, and when an irregularity is detected, the computer corrects timing in VVT (variable valve timing) engines, or triggers a DTC Diagnostic Trouble Code) in older vehicles.
    Read more: http://wiki.answers.com/Q/What_does_...#ixzz1N24uBya0
    2002 Chevrolet Silverado 1500 z71 __ Lifted 7" __ AirAid Cold Air Intake __ AirAid PowerAid Throttle Body Spacer __ Pacesetter Long Tube Headers __ True Dual Exhaust FlowPro Mufflers __ MSD Ignition Plug Wires __ Flex-A-Lite Dual Electric Fan __ 4.56 Gears
    I read someplace that any knock sensor failure/DTC defaults the PCM to the LO table.
    Jun 2010
    This is correct, knock sensor failure puts you into the lowest octane table you have. Going from a tuned high octane table to a low table you will feel absolutely gutless.
    Knock sensor replacement on LS1 engines are a pain. They're located UNDER the intake manifold. There is two sensors in two identical indentations on the top of the block. Moisture gets under the intake manifold and settles in those indentations and rusts the knock sensors. By bad design on GM's part.
    To replace the senors remove your intake manifold, and pop off the two rubber grommets that are on the top of the block, there should be one wire coming out of each.
    There's going to be a plastic connection that connects to the top of the knock sensor. I would highly recommend purchasing two new pigtails. 90% of the time they break during removal. Easy to replace, cut the wire crimp the two wires together from the pig tail to the stock wire, heat shrink it water tight.
    To remove the knock sensor just take your ratchet and socket and unscrew from the block.
    Then when doing the installation, be sure to use rtv silicone to seal the grommet water tight and air tight.
    Jun 2010
    Here's some real pictures from an 02' 5.3l that had knock sensors replaced.
    Intake Manifold Removed
    One of the knock sensors
    The other, you can tell why it doesn't work anymore. See the plastic from the broken connection during removal.
    Both knock sensors removed
    Connections on the knock sensors themselves rusted.
    The block, lots of moisture in there rusted.
    Jun 2010
    New knock sensor wiring harness
    New knock sensors installed with the harness hooked up
    Silicone job on the grommet
    All said and done, with a little more insurance on the top of the grommet.
  1. Knock Sensor Set-Up
    By ROYMAC in forum Petrol / Gas
    Last Post: August 18th, 2010, 12:02 PM
  2. Knock Sensor
    By BRD-PREY in forum Gen III V8 Specific
    Last Post: November 17th, 2009, 12:24 AM
  3. DTC O2 sensor
    By hymey in forum General (Petrol, Gas, Ethanol)
    Last Post: February 16th, 2008, 11:18 PM
  4. Knock sensor code
    By eboggs_jkvl in forum General
    Last Post: September 23rd, 2006, 07:15 AM
  5. Knock Sensor Logging
    By daveb in forum General
    Last Post: July 29th, 2005, 10:16 PM
