Page 13 of 15 FirstFirst ... 31112131415 LastLast
Results 121 to 130 of 141
Thread: 06-07 5.9L Feature Request List
  1. #121
    Mar 2013
    please add
    cruise control parameters
  2. #122
    Nov 2010
    Default 06-07 5.9L Feature Request List
    Such as?
    Les Szmidt
    2007 5.9 Dodge Ram
    EFI Live Cummins BETA Tester
    Silver Bullet Tuning
    silverbullettuning@gmail.com
    www.youtube.com/ljszmidt
  3. #123
    Mar 2013
    dead band amounts
    amount of correction based on error amount
    min max speed
    etc
  4. #124
    Nov 2005
    Cruise isn't controlled by the ECM, and will not be considered.
    Cindy
  5. #125
    Aug 2011
    Don't think this will be a prob. when csp5 comes out for you could have 1 file or hard wire the pin for 6th file for you high idle. This was my plan there for it would not be a loaded high idle [ie] like it is now technically is a pto function.
    Tuning by Zack StarLite diesel
  6. #126
    Mar 2013
    cummins ecu's have always controlled the cruise. if this is one the doesn't do you have any idea what module does?
    thanks
  7. #127
    Mar 2013
    two things
    can you add ability to select wether ecm listens to skim system
    (another words ignore any security stuff. like if i don't want to use skim keys or use engine in an another application)
    this would also solve the wrong vin used (oops) tow to dealer problem.
    and be able to select (activate) one of the five tunes when (tow\haul) is activated
    (that way we could set of a tune (especially trans stuff) automaticaly when (tow\haul) is active
    thanks
    justin
  8. #128
    Jun 2011
    Whats in csp is what you got. No further changes will be made to my knowledge. Isn't it just as easy to turn the knob when you press tow haul, its one more step.
  9. #129
    Mar 2013
    This would be an easy thing for you to add
    I don't want to plug in programmer just to select a different shift schedule
    would be a great feature for tune shops too
    And ability to ignore all the vin checks and security crap would solve many problems
  10. #130
    Junior Member kyle027's Avatar
    Jul 2014
    A desired boost table like the lml's have would be nice.
  1. Feature Request List
    By skneeland in forum Cummins 5.9L
    Last Post: June 13th, 2011, 04:54 PM
  2. Feature request v2
    By ringram in forum General
    Last Post: July 9th, 2008, 04:44 PM
  3. Feature request
    By stigmundfreud in forum General (Petrol, Gas, Ethanol)
    Last Post: July 6th, 2007, 11:05 AM
