Right..... Other than my injectors clearly toping out at about 5000 RPM why am i only producing 284 RWHP...... It is running a little too rich at 10.5/6 is on WOT but still surely LS1 with 5psi should be well in to the 300's at minimum.... will it be just the fact my injectors are over 80% when it needs it.....????
Attached is the run, tune and scan. My Commanded to Actual AFR is not too far out but not 100% hence the 10.5 at top end... its also a smooth curve.
Thoughts???
Dyno Run PE115.efi
V7.2 - PE115-SD-2BAR-COS5.ctd
