Results 1 to 3 of 3
Thread: 04 LB7 Speed Limiter
    May 2010
    Default 04 LB7 Speed Limiter
    I have disabled the speed limiter on other LB7's using B0747 but with this truck when I increase the mm3 past 90mph the truck still will not go above the limiter. Is there anything else I might need to adjust without disabling B0723. On my LLY I just needed to increase the Max fuel quantity vs speed table and I can go above the trucks limited speed. Any help is appreciated!
    Eric:2005 GMC Sierra LLY
    May 2010
    Does anybody have any ideas about this or suggestions on which tables to change?
    Hi Eric, can you post your ECM and TCM tunes up?
    2013 Sonic RS Manual - 1.4L I4T E78, bone stock (for now...)
    New site! SE22 Performance Custom Tuning
  1. Speed limiter
    By RichardWebman in forum V8, V6, L4 - E38, E67 & E37 ECM's
    Last Post: August 7th, 2009, 04:41 PM
  2. zr1 speed limiter
    By 69camaro5speed in forum V8, V6, L4 - E38, E67 & E37 ECM's
    Last Post: February 1st, 2009, 05:07 PM
  3. Removal of speed limiter
    By 06-6.0 SierraHD in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: April 20th, 2007, 04:49 PM
  4. Speed Limiter
    By devil in forum General (Petrol, Gas, Ethanol)
    Last Post: June 20th, 2006, 08:00 PM
