Results 1 to 9 of 9
Thread: 6.7L Cummins swap/transplant
    Nov 2011
    Default 6.7L Cummins swap/transplant
    Hi guys, kinda new to the forum thing, so please bare with me?
    I am in the midst of a 6.7 Cummins swap into a GM chassis and need some help please? The motor is a 2008 out of a low mileage Ram 5500 and I do have the ECU, harness & APPS. My main concern is wiring an OBD II port so EFI will be able to communicate and whether the CAN + & CAN - wires will need to be used since I will not be using the original BCM or TCM?
    I do have a diagram that I downloaded from the Dodge site that appears to be good but could use your direction please? My concern is being able to use EFI live upon its release to tune and eliminate emissions equipment since this will be an off road NON-emission application.
    Again guys, please & Thank U for any direction/suggestions!
    Nov 2010
    I dont think EFI can communicate with the C&C ECM...dont quote me, but I think its a different ECM.
    Les Szmidt
    2007 5.9 Dodge Ram
    EFI Live Cummins BETA Tester
    Silver Bullet Tuning
    silverbullettuning@gmail.com
    www.youtube.com/ljszmidt
    Nov 2009
    It reads but will not flash
    -Kory
    http://www.PPEI.com/
    Oct 2011
    The C&C and non C&C engines are the same parts wise, right ?
    He should be able to download a non C&C image and start with that, right ?
    I'm subscribing because I'm doing a 6.7 swap as well.
    Nov 2010
    Same parts...different ECM protocols.
    Les Szmidt
    2007 5.9 Dodge Ram
    Nov 2009
    The read has been sent to Ross :-)
    -Kory
    Nov 2011
    Hi guys, don't know if this will help any, but here is the info on the ECM..... if the upload goes right!
Name:	6.7 ECM 1.jpg
    I don't have any of my development stuff with me here on my trip, but I would expect we should be able to tune this combo no worries. The ECM type is correct (CM2100A).
    Not sure what this is all going in to, but if it's a late model GM vehicle don't expect the ECM to talk to the cluster etc, GM and Dodge CAN messages aren't the same.
    Nov 2011
    The application will be a mid eighties GM 1 ton 4x4 with a manual trans. So, no other control modules are present. No dash cluster worries either, I will eventually like to eliminate all emissions! Thank you all for the help!
  1. Issues with GTO 6.0 transplant Using 04-LQ4
    By 2Aspire in forum Gen IV V8 Specific
    Last Post: July 24th, 2011, 02:12 PM
  2. lq9 engine transplant
    By lq9nissan in forum Conversions / Aftermarket Parts
    Last Post: July 9th, 2011, 05:00 AM
  3. LS3 transplant / conversion
    By The Alchemist in forum Gen III V8 Specific
    Last Post: July 1st, 2010, 06:30 PM
  4. Transplant silverado problem
    By The Dirty Dutchmen in forum Gen IV V8 Specific
    Last Post: September 9th, 2009, 08:28 AM
