Results 1 to 5 of 5
Thread: Either P0602 or speed sensor codes
    Lifetime Member dansdieselp's Avatar
    Apr 2009
    Default Either P0602 or speed sensor codes
    Tuned a 07 5.9 that had a Smarty on it previously. The Stock file would throw a P0602 Checksum code. So took a fresh stock tune and flashed that in. The Checksum code went away, but now the truck throws wheel speed sensor codes and implausible speed codes. I'm wondering if the Smarty changing the ABS calibrations for tire size. Has anyone else had this issue? I figure have the dealer reflash both the ECM and ABS so we can start on a clean plate.
    Dan's Diesel Performance
    Specializing in Duramax, Cummins and Powerstroke Diesels
    Building and tuning trucks from daily drivers to full out competition
    www.dansdieselperformance.com
    Nov 2010
    I had to change OS to get a truck with the same issues to work right.
    Les Szmidt
    2007 5.9 Dodge Ram
    EFI Live Cummins BETA Tester
    Silver Bullet Tuning
    silverbullettuning@gmail.com
    www.youtube.com/ljszmidt
    Senior Member TexasCummins's Avatar
    Jul 2011
    I used my Smarty to program the ABS for my larger tires and never got that error. Try a different OS like Les suggested first. Then check the tire size parameter under Misc. in the tune and see if it's the correct one. I think the ECM parameter is for fuel economy calculations as it has no affect on the speedometer, but I could be wrong.
    EFI Live - The Smarter way to tune!
    On-Point Tuning
    2006 Ram 2500 4x4
    Apr 2009
    I tried every stock op system tune Andrew has on the tune depot. They didn't have the 602 code, but they all had the implausible speed sensor codes and skim key codes. So he's taking it to the dealer sometime for a complete system reflash then start over with a clean slate. It's just weird cause that's the first truck to give that kind of issue. I've tuned smarty trucks with no problem with a new op system and have changed the op system in my own truck also.
    Lifetime Member Dmaxink's Avatar
    Nov 2009
    I believe the ecm uses mm3 to calculate dic mileage...which means if a tune has the main pulse changed it'll be off. I'm having one particular truck with this issue as well Dan... next time its around I'm.saving the trace and sending to paul
    -Kory
    2006 2wd SC/LB lbz 72mmvvt & 60% sticks fully built 10.87@128.5
    2011 Denali LML
    Cummins beta tester
    Efilive Reseller (Power Performance Enterprises, Inc.)
    http://www.latuning.com/
    Gotta pay to play, make one change at a time, do a little searching then ask your question. The only stupid question is the one not asked...
  1. speed sensor
    By jhanner in forum General (Petrol, Gas, Ethanol)
    Last Post: October 28th, 2010, 06:55 AM
  2. Constant 02 sensor codes
    By RevGTO in forum Gen III V8 Specific
    Last Post: June 7th, 2009, 11:07 AM
  3. T43 DTC P0602 - Control Module not Programmed
    By gmh308 in forum 6speed RWD/FWD Transmission Tuning (incl T43, T76)
    Last Post: June 2nd, 2008, 08:58 PM
  4. Need help with a few codes.
    By slopokegtp in forum Gen III V8 Specific
    Last Post: July 27th, 2007, 12:36 PM
  5. o2 codes
    By johnv in forum General (Petrol, Gas, Ethanol)
    Last Post: June 5th, 2005, 07:20 PM
