Results 1 to 8 of 8
Thread: Dpf/egr delete for an lmm
    Jan 2012
    Default Dpf/egr delete for an lmm
    I have a 2008 lmm. I am currently running the edge juice with the attitude monitor. My buddy has a V2 and i am wanting to use it to strictly delete my dpf and possibly egr. I am going to continue using the edge for the performance side and efi live to delete my dpf. Which tables need to be changed in order to do this. From what I have read, it seems as simple as changing B2501 to No and B2502 to 0 and then setting the regin min engine temp to max.
    Lifetime Member Dmaxink's Avatar
    Nov 2009
    Just curious, why would you want to run the edge when you have the option of fully adjustable tunes/ much better tuning with efilive? Considering you will have to pay a vin license fee to flash it- why not just get a custom tune since your cable is already licensed to the truck?
    -Kory
    2006 2wd SC/LB lbz 72mmvvt & 60% sticks fully built 10.87@128.5
    2011 Denali LML
    Cummins beta tester
    Efilive Reseller (Power Performance Enterprises, Inc.)
    http://www.latuning.com/
    Gotta pay to play, make one change at a time, do a little searching then ask your question. The only stupid question is the one not asked...
    Jan 2012
    Its a money issue right now. Im sure I will go back later and do a full tune, but as for now I just want to delete the dpf and egr.
    Nov 2009
    -Kory
    2011 Denali LML
    Cummins beta tester
    Jan 2012
    Alright so just to be sure, all I need to change are the 2 tables and the regin temp?
    Nov 2009
    those 2 tables, temps, then the dtc(s)
    -Kory
    2011 Denali LML
    Cummins beta tester
    Jan 2012
    Awesome. Do you know which DTC(s) need to be changed off hand.
    Dec 2012
    Quote Originally Posted by Dmaxink View Post
    I understand that the DTC controls are in "Engine Diagnostics" -> "DTC Enables"
    Where are the temp settings?
    Are you referring to C1901 through C1908 (which are time values) in "EGT Sensors"?
    Are any changes required to C1909 (minimum RPM), and C1913 (minimum ECT)?
  1. DPF and EGR Delete
    By pONSi in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: April 13th, 2010, 10:48 AM
  2. dpf delete help
    By escalante127 in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: January 6th, 2010, 08:27 PM
  3. Dpf delete
    By LIL DAVE in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: September 9th, 2009, 07:24 AM
  4. 7.5 LMM DPF delete and EFI V2
    By clickjocky in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: February 5th, 2008, 03:36 PM
