How can I turn this light off?
You can't disable it (other than unplugging it), but you can clear the DTC...
( from the scantool you can clear the DTC's from all modules in one go )
First, go Edit->Properties and
- on the Advanced tab checkmark Check/Clear DTCs for all Modules;
- on the Options tab checkmark Active Module Detection;
- click OK to close the properties window.
Then, connect to vehicle, and:
- on the OBDII tab goto the Modules subtab to make it show all the modules;
- go Info->Clear DTCs for all Listed Modules.
Take note that if the SDM module has a problem it will throw the DTC again and cause the airbag light to come on again.
its coming back.... what could the problem be? I just want it to go away. forever.
A little more information would be helpful. If this is an OEM configuration - take it in to the dealer and have it checked - airbags really helpout when bad things happen.
If you have switched the IPC (gauge cluster) - as an example, with trucks - switching to an IPC that has a trans temp gauge, from one that did not - may set off the airbag light - if the donor IPC is not 100% compatible.
Describe your configuration, and when the problem began ... someone may have an answer for you.
Regards,
Taz
ok well,
I bought this car (01 camaro) with a blown engine. After fixing it I noticed that the air bag light is on and when I first start it it will blink then just stay on. the code its coming back with is b1001
Borrowed from someplace on the web:
GM Technical service bulletin TSB Class 2 trouble code B1000, B1001, B1271, B1780
Class 2 Serial Data Communication allows control modules (i.e. the Powertrain Control Module (PCM), the Body Control Module (BCM), the Dash Integration Module (DIM), the Instrument Panel Cluster (IPC), the radio, the Heating, Ventilation and Air Conditioning (HVAC) Controller, and the Sensing and Diagnostic Module (SDM) to exchange information. This information may be operational information or identification information. Among the identification information exchanged and compared within these modules is the Vehicle Identification Number (VIN). Typically the one module, the master module, broadcasts the VIN and all the other modules compare the VIN stored within itself. When the broadcast VIN does not match the VIN stored within the SDM, the following actions occur:
• DTC B1001 Option Configuration Error is set and deployment of the airbags is inhibited.
• DTC B1271 or a DTC B1780 Theft Locked. Additionally, the master module will compare the SDM's part number (last four digits) to determine if the correct SDM is installed in the vehicle. If the SDM is the wrong part, a B1001 will also set.
The VIN information is also used by the radio. When the VIN does not match the VIN stored within the radio, DTC B1271 or DTC B1780 is set and the radio is inoperative.
This situation may occur when a vehicle is being repaired. When a PCM or a body control type module is replaced, the VIN information must be programmed into the replaced (new) control module. A module which has had VIN information entered into it (for example, one taken from another vehicle) cannot be reprogrammed. VIN information can only be entered into new modules. The ignition must be ON in order to program the control module. Since the VIN information is broadcast when the ignition goes to ON from any other ignition switch position, DTCs may be set in the SDM and/or the radio. Therefore, always follow the specified control module replacement procedures.
Check for a VIN mismatch ... I recall another thread with a Camaro having the same issue. The VIN in the PCM must match the VIN for the BCM / vehicle.
The odd time a reflash (by any device) may alter the VIN - often zero of question marks when checked.
Regards,
Taz
Joecar, you are always ahead of me !!
This is the thread I was referring to ...
http://forum.efilive.com/showthread....ght=camaro+sdm
Regards,
Taz
damn you guys are awesome! Now... is there a way for me to go into the BCM and read the vin or change the vin?
so with the v2 i'm reading that its code B1001 and status says ---H-NCI can anyone tell me what this status means?
