Worked for me. Thanks!
2019 Ram 6.7L 68RFE
2003 VW Jetta TDI
There are two file systems that can be formatted. If you format the DATA file system, that will have no effect on your config files. You'd need to format the CONFIG file system. If the CONFIG file system was formatted then there would be no files left in the CONFIG file system (i.e on the [F9: Config Files] tab page) for you to delete. It may be possible that you formatted the DATA file system, thinking it was formatting the CONFIG file system.
Some background info that may help...
You can only format the CONFIG file system from a PC, using either the drop down menu format option of the [Program] button in the BBX setup window, or from the [Format] button on the [F9: Config Files] tab page in EFILive Explorer.
You can only format the DATA file system using FlashScan's or AutoCal's on-board file system format option.
The reason you cannot format the CONFIG file system from the FlashScan or AutoCal device is so that you do not accidentally format it while away from a PC (i.e. at the track). If you did that then your device is useless until you can reload the config files from your PC.
Can I install the V8 package without the FTDI driver??????
I would like to have the V7/V8 on one laptop for editing the tunes but not touch my existing FTDI drivers...
Wolfie
LS1B 2007 Express 6.0 /w 470,000+ miles (parked as of 01April2011)
I tried to upload a new file into my truck today. .. I keep getting EFI Live script exited with code $312 Sub Function not supported or invalid.... I have updated everything to the newest version and firmware.. If someone could help me out I would appreciate it... Thanks.
There's a bunch of information we'd need to collect from you to help track down the problem, it would be best if you logged a help desk ticket here: http://support.efilive.com/
Did your tuner lock it?
