Results 1 to 7 of 7
Thread: 5 wire maf/iat sensor
    Jan 2012
    Default 5 wire maf/iat sensor
    hi just wondering how to get a iat sensor signal back to the ecu once the 5 wire maf/iat sensor has been removed cheers
    Dec 2007
    In the case of a MAF/IAT you need to modify the cable to only remove the MAF signal to the PCM leaving the IAT lines intact in the connector. I think the process is outlined in the E38-VVE Set-up Guide.
    http://forum.efilive.com/showthread....VE-Setup-Guide
    -Adam Chant
    Tune it or lose it!
    2007 Saturn SKY 2.4L Automatic - E67
    EFILive Tuned
    Jan 2012
    Yer I know this method but I have completely removed the whole Maf sensor can a iat be installed from a ls1 by using the plug and sensor from a ls1 and grafting it into the e40 harness
    swingtan
    Guest
    Just wire in an LS1 style sensor to the existing loom. Many have don this, but I don't have the details ATM.
    Senior Member Dieselman's Avatar
    Apr 2010
    Pretty sure it is the two brown wires that are for your IAT sensor
    Senior Member Sid447's Avatar
    Jul 2005
    Quote Originally Posted by vcls1 View Post
    You need PN 12160244, Sensor Intake Air Temp.
    Also PN 12110620 Connector, Sensor Int Air.
    You then need to cut a hole in your maf-pipe slightly larger than the sensor, fit a grommet* and dab it with detergent or swarfega and push the IAT sensor into it with the relevant wires connected.
    If you have a GTS maf-pipe the hole's already there.
    * I used a 2001-2004 LS1 coolant header tank mounting grommet (same is used to mount the air filter box too on these cars).
    Jul 2003
    go to www.eficonnection.com
    Problems solved!
  1. 4 wire Universal NTK Narrow Band O2 sensor wiring?????'s
    By GAMEOVER in forum General (Petrol, Gas, Ethanol)
    Last Post: January 19th, 2011, 10:40 AM
  2. IAT Sensor when MAF bypassed
    By Robbie The Wrench in forum Gen III V8 Specific
    Last Post: August 16th, 2008, 08:33 AM
  3. 5 Wire MAF IAT
    By shakinlm7 in forum General (Petrol, Gas, Ethanol)
    Last Post: October 2nd, 2007, 03:20 AM
  4. IAT sensor
    By Chevy366 in forum Lounge
    Last Post: August 3rd, 2007, 11:49 AM
  5. Temporary IAT Sensor Solution to 5 Wire MAF
    By S10Wildside in forum General (Petrol, Gas, Ethanol)
    Last Post: October 8th, 2006, 01:29 PM
