Results 1 to 9 of 9
Thread: ERROR $0194: write failure
    Jun 2012
    Default ERROR $0194: write failure
    Can someone tell me why I am getting this error when trying to transfer my tune file to autocal in EFI live explorer?
    Quote Originally Posted by EFILive Error Codes.pdf
    $0194
    F_ERR_WRITE
    Usually this means that the target file system is full.
    If you are programming BBX configuration data, try reformatting the Config file system using the drop down option on the [Program] button. Then [Program] the BBX configuration data again. If you are reading or data logging, check that the SD Card (or FlashScan’s/AutoCal’s internal memory) has enough free space.
    Setup your BBx to include only the ECM/TCM that you use, delete all entries involving others, Save, Format the Config space, Program;
    Jun 2012
    Hey Joe! man you have been a great help to me. I just got my tune in from my tuner. I downloaded it and moved it to my tuning files folder on my PC. Went to EFI Live Explorer and clicked dragged it to the lower pane which represents Autocal under "tune" in the F3 data files. The tunes show there. My question is: Is the autocal now ready to install the tune in the truck? Or do I nned to do another step?
    Mar 2011
    what if your getting this error code and tune all types of vehicles, I got mine down to 95 percent and get the code when loading a tune on auto cal
    Joe Kupferschmid
    Daves Diesel Angola
    www.angoladavesdiesel.com
    Diesel and gas tuning
    Personal Vehicles tunes with efi 06LBZ, 05lly, 2002 Z28, 2004 Gto
    Mar 2011
    just switched v2 to only cmc2100 and still wont let me add my 5th tune to auto cal
    Joe Kupferschmid
    Daves Diesel Angola
    I don't think AutoCal has sufficient internal flash memory for that many tune files.
    Mar 2011
    anyone?
    Joe Kupferschmid
    Daves Diesel Angola
    Post a screenshot of V8 EE showing the AutoCal data files folder and the tune files you want to copy on there.
    see this:
    $0194
    F_ERR_WRITE
  1. $0194 write error
    By J.Abbott in forum AutoCal
    Last Post: March 12th, 2012, 05:24 AM
  2. error $0194
    By blackbeast ss in forum FlashScan V2
    Last Post: October 7th, 2011, 02:48 PM
  3. $0194 error when trying to program V2....
    By LPDTuning in forum FlashScan V2 BB Logging
    Last Post: December 27th, 2009, 11:37 AM
