Page 1 of 6 123 ... LastLast
Results 1 to 10 of 54
Thread: 2011 gmc 2500 hd bootloader rejected ?
    Member JST's Avatar
    Jul 2007
    Default 2011 gmc 2500 hd bootloader rejected ?
    Working on a 2011 GMC 6.0 gas,I think it has a E 67 ECU,I keep getting rejected,I did try the try alt keys no help but I got this (engine speed is not at 0,speed not at 0 or a flash memory fault) The newer truck are a pain in the a// Any help ???
    2002 GMC 2500HD 4x4 SCLB STOCK MOTOR WITH TOMAN TUNING,FASS 150, M/A TRANS,11.90 ON A GOOD DAY IT'S MY WORK TRUCK,19 TO 21 MPG WITH ME DRIVING,THE TRUCK (OLD RED )HAS 909,000 MILE AND LOVING IT,285/75/16
    Member JST's Avatar
    Jul 2007
    Pulled the ecu out and it is a E 78,Not good EFI dose not support E 78,they have 11 truck for tuning and all are the same 2011 GMC with the 6.0,can HP Tuners tune E 78 ? Tuned 2 older trucks they have and got 2/3 mpg
    Lifetime Member Rhino79's Avatar
    Jul 2006
    I have tuned on e78's with efilive.......
    http://www.efilive.com/index.php?opt...147&Itemid=146
    Head Calibrator
    Gwatney Performance Innovation
    Jacksonville, AR 501-982-2102
    Apr 2008
    do you have the latest software?
    i think its newer addition
    stock sucks
    Member JST's Avatar
    Jul 2007
    Yes I just checked
    Quote Originally Posted by JST View Post
    Oh dear, what can I say, time to update your software. EFILive has has E78 support since late 2010!
    Maybe you are only installing v7.5 updates, in which case you won't see the E78. The E78 needs to be done via the V8 software. On the download page on the website you will find links for both.
    Member JST's Avatar
    Jul 2007
    Just checked again,up to date
    Apr 2008
    try doing it with efi live v8 to read and wright and v7 to adjust tune
    stock sucks
    Did you install the V8 software?
    Here's what you should do. Download both v7.5 and V8 from HERE. Manually uninstall your current v7.5 software because I would suspect it's an earlier version that what the installer used in the link is. Once you've uninstalled your older version of v7.5, install both v7.5 and v8 from those downloads.
    Some of the new ECM's are only supported for reading and flashing via the V8 software, E78 being one of them. You read the ECM with V8, still edit and scan via V7.5, but then also reflash the controller via V8.
    Member JST's Avatar
    Jul 2007
    Can you run 7.5 and 8 on the same computer ?
  1. Bootloader Rejected Need HELP Please
    By EVI in forum E37, E38 & E67 PFI ECM's
    Last Post: November 16th, 2012, 05:55 AM
  2. bootloader rejected
    By relentless addiction in forum Duramax LLY
    Last Post: May 25th, 2010, 06:26 PM
  3. Bootloader rejected
    By lilly in forum Duramax LLY
    Last Post: June 28th, 2009, 01:48 AM
  4. bootloader rejected
    By dmax687 in forum Duramax LLY
    Last Post: November 7th, 2008, 11:43 PM
  5. Bootloader Rejected
    By KWSUNDELL in forum Duramax LLY
    Last Post: October 21st, 2007, 07:32 PM
