I'm a newbie here and to EfiLive. I recently installed a new DPF (long story) and the exhaust guy messed up and welded the pressure sensor due to a stripped plug. Ive been having troubles since, the worst is that the egr is on all the time. I pulled the solenoid and it seems to be working properly, but it is fully extended when the engine is running.
Instead of replacing the solenoid, I put it in the glove box and taped off the wire. The engine is running much better I need to smog in a few weeks, so I'm looking for a replacement DPF. I've got the V2, but I'm still going through the manuals and plan to tweak the tuning after smog.
Question, Is it going to be ok to drive without the solenoid for a few weeks?
