Page 1 of 4 123 ... LastLast
Results 1 to 10 of 40
Thread: emissions
    Lifetime Member ZL1Killa's Avatar
    May 2005
    Default emissions
    My secondary air system is saying not ready, which it is connected and the tune is the EXACT hypertech tune, except the PE table and the spark table.
    Air pump on time is 190 and all the other settings are default(stock)
    ALSO the oxygen sensor heater says not ready. I deleted my rear O2's (put sims on them, and then ended up putting them to not reported)
    I do not know if the heater means the front oxygen sensors, or the rear. I THINK the front. But why wouldn't they be ready???
    I have a wideband hooked up and I'm reading excellent AFR across the board(~14.6 at idle and part throttle) and the car has been driven around 225+miles. Several of the 'not ready' items have become ready...do i need more driving?
Name:	EPA stuff to pass.JPG
    01 T/A WS6 #4984 STOCK 342HP and 352TQ [/b]MODS:Too many to list, PM...funny rear mount.. father/son build.
    [Quote :ur car is sneezing!!!!]
    I KNOW KUNG FU.
    My STS build: http://www.ls1tech.com/forums/showthread.php?t=631954
    453HP 475TQ @6psi
    .....CAM'd, IC'd, and 7psi'd #'s coming.....
    May 2005
    ......maybe??
    I KNOW KUNG FU.
    453HP 475TQ @6psi
    Jan 2004
    Email me your tune and I'll take a look at it for you.
    May 2005
    can 01 cars run without the MAF and not have the DTC codes shown in efi live or when testing for inspection
    I KNOW KUNG FU.
    453HP 475TQ @6psi
    May 2005
    I THINK I FIGURED OUT THE PROBLEM.
    THE secondary air pump runs with the 02 heaters when the AIR PUMP runs and it performs a test by seeing the changing voltage(i think)
    HAS ANYONE GOTTEN AWAY WITH PASSING INSPECTION with the AIR PUMP REMOVED
    I KNOW KUNG FU.
    453HP 475TQ @6psi
    May 2005
    and as my car is a 2001 it can only have 1 not ready code
    I KNOW KUNG FU.
    453HP 475TQ @6psi
    Nov 2003
    Thumbs up
    Quote Originally Posted by ZL1Killa
    I setup a special tune that shows everything ready and no codes. Did not need a driving cycle. I just stopped before the inspection and downloaded this tune , passed no problem. IT WAS JUST SETTING UP THE DIAG CODES TO SHOW ALL READY. I do not have AIR, MAF,CATS or O2's.
    Bill
    2011 Camaro 2SS/RS L99 RJT
    VMax Ported RJT Throttle Body
    Gorilla Wheel Lock System;
    May 2005
    pm sent to ya...need help on this as my inspection is already 3 months late.....LOL long story
    I KNOW KUNG FU.
    453HP 475TQ @6psi
    Nov 2003
    Tune send. Good luck.
    Bill
    May 2005
    now when i turned off my maf codes (to NOT REPORTED) the car didn't want to run??
    Now, when i did turn the MAF codes to not reported the MAF was OFF of the car. Then I programmed the tune in and cranked the car and then it
    idled funny and then cut off.
    or does switching all those codes off that you sent me, Bill allow for the car to run? I saw the 02s(open loop of course), the MAF, AIR,...etc
    Right now I'm going to run as is to get inspected and pass, as the AIR crap is back on.
    Me and my friend are going to dial in the MAF, AFTER INSPECTION and turn off the air pump completely, so that it will never come on and cause bad readings on the wideband during dial in.
    Nick Williams is running the MAF and I'm curious as to how my car will perform with it calibrated correctly, as my past dyno numbers were my best with the MAF....however if it doesn't go good, I will DEF. go Open Loop...as before the car was running fine
    I KNOW KUNG FU.
    453HP 475TQ @6psi
  1. Emissions not readys
    By 64camino in forum Gen III V8 Specific
    Last Post: May 28th, 2010, 08:25 AM
  2. Non-Emissions or Not Reported?
    By GAMEOVER in forum Gen III V8 Specific
    Last Post: May 9th, 2010, 08:05 PM
  3. Can't pass emissions?
    By WS600 in forum Gen III V8 Specific
    Last Post: March 11th, 2008, 12:37 AM
  4. Emissions codes?
    By NewV in forum Gen III V8 Specific
    Last Post: April 3rd, 2007, 03:29 PM
  5. Another emissions question
    By slowhawk in forum General (Petrol, Gas, Ethanol)
    Last Post: March 25th, 2006, 01:05 PM
