Results 1 to 10 of 12
Thread: EFILive RC 3 (April 08, 2013)
    Default EFILive RC 3 (April 08, 2013)
    The latest EFILive software is now available as Release Candidate 3 for all EFILive customers.
    EFILive encourages customers to use this release in their production environments.
    This release is scheduled to become the official public release.
    Download here:
    Updates since RC2:
    • Added search option in [F8: Tools] window to search through *.ctz and *.pld files for user defined criteria. The search option does not search V7 files (*.tun or *.efi) yet.
    • Fixed LLY flashing and auto-locking problems.
    • Fixed LB7 auto-locking problems
    • Added option to Un-link AutoCal device (its in the same place as the link option). You can only un-link an AutoCal if you have the FlashScan device that was used to link it in the first place.
    • Some other minor bug fixes
    Firmware
    • Since RC1, the FlashScan and AutoCal firmware version number has been updated to V2.07.36. That means once you upgrade the firmware you cannot revert back to V2.07.35.
    • The firmware version number upgrade was required because of the seriousness of the "SD Card surprise removal" bug that was fixed in RC2.
    What is not included in this release:
    • The Cummins switchable tune (CSP5) feature is not included in RC3.
    • The DPF/EGR restrictions for US based customers are not part of RC3.
    • Pass-thru logging using the V8 software is not included in RC3 (use V7.5 for pass-thru logging duties).
    • Tune file editing using the V8 software is not included in RC3 (use V7.5 for tune file editing duties).
    Bug Fixes:
    Bugs that have been reported over the past 6 months have been fixed in this release. If you have reported a bug but discover that it has not been fixed or has only been partially fixed in this update, please report the bug again in this thread.
    Known Issues:
    Please post issues, questions, clarifications (large or small) in this thread.
    As issues are reported and confirmed they will be re-posted as "Known Issues" below.
    • E55 cal-flashing fails with mis-matched operating system. (fixed in RC4)
    • E39 cal-flashing of *.coz files fails with "incorrect checksum" due to badly formatted *.coz file. (fixed in RC4)
    • Pass-thru data logging fails when less than 24 channels are selected and external A/D PIDs are selected and voltage applied to AD1 thru AD4. (fixed in RC4)
    • g-force units are not defined in sae_generic.txt. (fixed in RC4)
      To fix the g-force error, please download the attached sae_generic.txt file and save it (or copy it) into the folder:
      \Program Files\EFILive\V7.5\Configuration (Win 32 bit systems)
      or
      \Program Files (x86)\EFILive\V7.5\Configuration (Win 64 bit systems)
    • Fixed metric/custom scaling issues when using slider to test custom PID units for BBL PID selections. (fixed in RC4)
    The EFILive Development Team
    Senior Member Behold's Avatar
    Apr 2010
    Not sure if still an issue in rc3 but when you bbx log or scan on laptop then open the scan to minipulate on to the tune tool it moans the car vim does not match.
    Looks like the vin on the scan is blank.
    Using an ls1b controller on a v2
    Thanks Antony
    Holden Commodore GTS - LS1 5.7
    12 rib Crank Driven Vortech V2 Centri Charger (Intercooled) 9 PSI.
    LS6 Intake
    LS6 Heads
    YT 1.7 Roller Rockers
    BTR Dual Spring with Ti retainers
    BTR Hardend 7.400 Push rods
    Comp Cam JAMCAM
    2 Bar Map
    Mafless
    LS2 Coils
    PCM LS1B with 512KB Running COS5 v01290005
    Lifetime Member izaks's Avatar
    Aug 2003
    Newly added g-force causes Scan to fail with error ERR_CONFIG/92
    Line 812 - Units gforce not found
    Used previous version of sae_generic.txt - problem solved
    2011 VE SSV 419 + CAM + Whipple 2.9FF SC + PPV front struts + Bilstein rear shocks + 6L90E with single piece carbon fiber prop
    Aug 2003
    Tried to comment out references to g_force, but error reported always seems to be one line out
    Line 812 *UNM-08-135
    Line 813 g-force -8.0 8.0 .0 * 1.0 -8.0
    Aug 2003
    Ok, commented all references to g_force, and problem is solved
    Apr 2010
    Default T43 table missing in OS 24237276
    I don't see the fix I requested for OS 24237276 on the T43 controller where its missing the Pattern B shift time tables. "Desired Shift Time Input Torque Mod (Pattern B)"
    Dec 2006
    Thank you for this fix Fixed: LB7 auto-locking problems
    Quote Originally Posted by Behold View Post
    I just checked with RC3 and the VIN is captured in the log file during BBL.
    When you try RC3, let me know if you still see issues.
    Quote Originally Posted by izaks View Post
    My mistake - I updated a PID just prior to releasing RC3 without retesting - it was such a simple change what could possibly go wrong!!!
    Obviously even the simplest changes will bite me in the ass if not tested properly.
    Will fix asap.
    Mar 2009
    Yeah because of the g-force error I get no capability to tune or scan.
    2002 Chevy Duramax with a few supporting mods.
  1. 2013 EFILive Training Classes
    By zfuller123 in forum General (Diesel)
    Last Post: September 23rd, 2013, 04:22 AM
  2. EFILive RC 2 (March 28, 2013)
    Last Post: April 8th, 2013, 11:24 PM
  3. EFILive RC 1 (March 01, 2013)
    Last Post: March 27th, 2013, 09:00 AM
