Results 11 to 20 of 21
Thread: Plx sm-afr v2 serial mods
    Jul 2003
    Yeah... not flashscan v3......
    The PLX seems nice... cheap.... i don't know if its any good, but the ability to detect sensor timing is rather nice.
    Dec 2006
    Guys I just got this setup, it's very nice. I am sure I will have lots of questions but doing tons of reading first. It is touch screen and very high quality. (DM-6 with SM-AFD Gen. 3) So far it's in my catless downpipe with only one bung, simulating narrowband and I am daily driving it. Must hook up to EFILive asap as the car is desperate for tuning.
    8.7 @ 84 (1/8 mile) bolt-ons
    Dec 2006
    Now that I said that, it seems now (today) I'm easily bumping into that thread
    [ turns out I had already bookmarked in the "Collecting scattered links" thread and did not realize it ]
    PLX-SM-AFR-Serial-upgrade
    After reading through that entire thread, I have a couple of questions.
    1.) Can I just start tuning using the analog output as designed and get decent results (compared to untuned)?
    2.) Does my brand new Gen3 PLX even need to be modified this was or has it improved in some way?
    3.) Since I am running the multi-gauge full time from the serial jack - could I still do this in the future?
    Thanks!
    1) yes, you can, but you have to first measure the voltage offset, and add/subtract it in the calc pid.
    2) IDK.
    3) No/IDK.
    Dec 2006
    2) IDK.
    3) No/IDK.
    Thanks Joe! Would it be too much to ask for a link to an explanation of your answer to #1?
    You measure the voltage output of the wideband using a DMM, and compare that measurement to what V2 reads... if they are different, you have to adjust for it using a calc pid.
    Another way of automatically doing this, thanks to 5.7ute/Mick, is to use one of the other analog inputs to measure to offset on the fly, and subtract this in the calc pid.
    I'll try to find links..
    Dec 2006
    Apr 2007
    Bump for another old thread. Doing some research on getting a new WB but I want use the serial cable feature on EFILive V2. I'm looking at the PLX SM-AFR Gen 4 because it uses the LSU 4.9 O2 sensor. It has a digital input and output as shown in the pic below. My question is can I use a TAQ LC-1 serial cable to connect from the digital output of the PLX to the V2 or do I have to use the analog connector? Any help is appreciated.
  9. #19
    Mar 2012
    Quote Originally Posted by DrkPhx View Post
    I use the exact same plx. To talk serial with the V2 I modded the PLX and installed a 232 socket and soldered it to the PCB. Pretty easy mod to do. I can take some pics later but my car is in a shop atm. Will be a week or so
  10. #20
    Senior Member RandyWS6's Avatar
    Jan 2005
    Quote Originally Posted by barbermi View Post
    Any update or pics of the wiring diagram for the Gen4 ,Fixing to install on my new C7
    Thanks,Randy
    2000 WS6 TransAm-M6 LS3 forged 422 cid. 4L80 FMVB ,4:22 Ford 9"-35 spline axles
    2014 C7 3LT-Z51 Corvette Stingray M7 , A&A Supercharger , Kooks 1-7/8" long tubes & X Pipe 615 rwhp & 560 rwtq
    http://community.webshots.com/album/259987907DcztOG
  1. PLX SM-AFR Serial upgrade
    By ntae in forum FlashScan V2 BB Logging
    Last Post: May 25th, 2017, 08:26 AM
  2. setting B3618 PE AFR with cam and supporting mods
    By myws6formula in forum Gen III V8 Specific
    Last Post: June 17th, 2013, 12:47 PM
  3. plx sm-afr serial
    By blazinblue in forum General
    Last Post: June 23rd, 2009, 08:29 AM
  4. PLX SM-AFR Serial control not found.
    By aaronr in forum FlashScan V2 BB Logging
    Last Post: February 15th, 2009, 08:59 PM
  5. Anyone willing to convert my PLX to serial???
    By exploder in forum General (Petrol, Gas, Ethanol)
    Last Post: November 16th, 2008, 04:51 PM
