Page 1 of 5 123 ... LastLast
Results 1 to 10 of 42
Thread: Valet mode finally
    Oct 2005
    Default Valet mode finally
    Ok, Its finally done. Valet mode lives.
    My 99 HSV R8 didnt have a wire connected to the right pin. In fact nothing was connected at that point, just a hole in the connector. The PCM had the pin to accept the wire, so I did some investigations.
    I thought I might know where I could find some wire with the right connector socket to fit the pcm. I ended up using a piece of wire from an old computer case. You can use one of the wires that connects to the mainboard for speakers, power on led, reset switch etc. The end that connects to the mainboard can be separated from the plastic "jumper" with a pin. You end up with a piece of wire terminated in a small metal socket.
    Ok next step was to get the right pcm socket. The custom OS tutorial has the details for this. The socket is also numbered so its not too hard. I had to poke the rubber seal through with a fine drill bit then pushed the wire through. It has like an arrow head tab on it so it goes in one way and doesnt come back out. This helps when you push the pcm socket back onto the pcm so the connectors slip over all the pins and dont come back out.
    Once done I just needed to extend the length of the wire to a toggle switch. Actually Id got to this point a few weeks ago. However drilled my first hole slightly too high up, so I left it lying lose. (Bad idea as the car cut out on a couple of occasions during some spirited cornering! At least I knew it worked)
    Anyway got it all wired in properly today. Just a simple 2 pole toggle with open and closed (earthed). Works well. Pretty well hidden if you mount it on the header tank bracket. But some may like to put it somewhere more stealth. 20mph and 2000 rpm max on valet now, works very well.
    Just wanted to let everyone know, just in case they had the issue with no wire available to tap into. Just swipe one from an old PC
    2014 VF SV LS3 Maloo.
    Lifetime Member BowlingSS's Avatar
    Nov 2003
    I might just try and install one.
    Bill
    2011 Camaro 2SS/RS L99 RJT
    CAI, Inc. Cold Air Induction;ADM Scoop
    Rx Catch Can;Rx Breather;Roto-Fab Washer Container
    VMax Ported RJT Throttle Body
    XSPower Headers and XSPower 3" Exhaust System
    Elite Engineering Tunnel Brace,
    Gorilla Wheel Lock System;
    Tinted Windows 35%;EFILive Tune
    Lifetime Member oztracktuning's Avatar
    Nov 2005
    What would be some good settings to put in it - to just disable the car from the switch rather than let it run at all. Maybe it will start but not go anywhere? Just looking for some options.
    1/ Disable totally
    2/ A good safe true valet mode setting so its driveable but not stealable (at a sensible speed)
    Oct 2005
    Ive not tried disabling totally. But I set it to 1000rpm and like 4 kmph before I went away once. Came back started it up and it wouldnt go anywhere. Any throttle almost killed it, it only idled. And driving anywhere, forget it.
    Try max rpm of 600 or something that might keep it dead. Let us know what happens.
    Else I recon Max rpm of 3000 and mph of 30 for a true valet mode.
    Guess who's back!!!! Black02SS's Avatar
    Jan 2004
    Quote Originally Posted by ringram
    I might have to try this just for that reason... Might work great for a anti-start device.
    Is the Valet Mode on all PCMs? I have a 2000 silverado 5.3 with a 2002 PCM. Do i have it? I cant find it on EFI Live.
    Thanks guys!
    I think you need COS3 or COS5.
    Please explain COS3 and COS5..
    I now have Commercial Upgrade, So do i have the abilites?
    Yes, Commercial FS allows you to flash in a different OS (including a Custom OS).
    The Custom OS Tutorial explains how to do it...
    http://www.efilive.com/download.aspx#downloads7
    Also, look in the COS section of the forum.
    Thanks Joe!
  1. E40 Valet mode?
    By ringram in forum Custom Operating Systems
    Last Post: April 27th, 2007, 10:21 PM
  2. Valet Mode
    By ZL1Killa in forum Custom Operating Systems
    Last Post: April 10th, 2006, 01:08 AM
  3. Can Valet mode be used to turn SD mode off and on?
    By ForcedC5 in forum General (Petrol, Gas, Ethanol)
    Last Post: May 17th, 2005, 11:53 AM
