Page 1 of 4 123 ... LastLast
Results 1 to 10 of 33
Thread: calc.vet without wide band o2 please help
    Jun 2014
    Default calc.vet without wide band o2 please help
    ok so new to tuning
    trying to do calc vet
    when transfering selbens over to tune file dosent work
ID:	17131Click image for larger version.
ID:	17132Click image for larger version.
ID:	17130Click image for larger version.
ID:	17133Click image for larger version.
ID:	17134Click image for larger version.
Name:	efi_copy with labels.jpg
ID:	17135Click image for larger version.
ID:	17136Click image for larger version.
Name:	efi_after pasteVE.jpg
ID:	17129Click image for larger version.
Name:	efi_cant do part.jpg
ID:	17137Click image for larger version.
Name:	efi_cant do partselbens.jpg
ID:	17138Click image for larger version.
ID:	17139Click image for larger version.
Name:	the big problem.jpg
    Jun 2014
    Jun 2014
    Jun 2014
Name:	paste and multiply by 50%.jpg
ID:	17143 paste and multiply by 50% seemed to work but why???
    Are you following post #1 in this thread: Cacl.VET thread...?
    If you have no wideband, you have to edit the CALC.SELBEN pid in calc_pids.txt to always use CALC.LTFTBEN.
    In your maps, you forgot to include the units on the axis (in map properties, on Col and Row tabs, checkmark Show Units).
    Jun 2014
    yes calc.vet thread
    ok got maps changed !
    how do i know what lines of code refer to selben.... maf vs. sae.rpm??
    or do i just delete the wbo2 parts ???Click image for larger version.
ID:	17146Click image for larger version.
Name:	CALC PIDS .jpg
    can i rename it?? dumb question ...probably not...
    Jun 2014
    can somebody help?? what exactly should my calc_pids.txt look like??
    would it really matter since i have no wbo2 there is no input from that...
    do i just delete clc 00 220 ???!!
    im a tradesperson not much programming background.
    thanks in advance!!
    Aug 2013
    Joecar has already told you what to do.
    i.e. in calc_pids.txt change this:
    Code:
    *CLC-00-220
    factor             0.5           1.5       .4  "iff({CALC.CL}, {CALC.LTFTBEN}, {CALC.WO2BEN})"
    to this:
    Code:
    *CLC-00-220
    factor             0.5           1.5       .4  "iff(1, {CALC.LTFTBEN}, {CALC.WO2BEN})"
    using a non-formatting editor (e.g. like Notepad, and not like Word).
    And of course, you will have to filter out all data for which CL is not 1 (i.e. with LTFTBEN only, then only the frames for which CL is 1 are valid).
  1. Replies: 83
    Last Post: September 5th, 2023, 12:30 PM
  2. I need help with my wide band
    By isak81 in forum External A/D inputs
    Last Post: January 8th, 2012, 03:46 PM
  3. Calc.VET, VET Map Average is all 0.0?
    By n8dogg in forum Gen III V8 Specific
    Last Post: July 15th, 2011, 02:20 PM
  4. wide band o2
    By woody69 in forum Custom Operating Systems
    Last Post: October 23rd, 2006, 04:19 PM
  5. lm-1 wide band
    By 69camaro5speed in forum General (Petrol, Gas, Ethanol)
    Last Post: January 6th, 2006, 08:39 AM
Tags for this Thread
