Results 1 to 2 of 2
Thread: Lean Cruise COS3 LS1B
Hybrid View
    Apr 2010
    Default Lean Cruise COS3 LS1B
    Hi I have a 2003 Silverado 1mb PCM with COS3 03150003. I found the lean cruise CAX that is based on the original OS 12579405 and renamed it 03150003. I then saved it in the EFILive\V7.5\Calibrations folder. Now when I open the tune file I get an error "[B9000]'s address $02AAB8 is outside the calibration address boundaries" Am I doing something wrong? I have updated both computer and V2 to the latest versions and I also get the same fault on an older computer running an earlier version.
    Cheers.
    Just thought I would also add that I get the same error even if I use the original CAX file with an original Silverado tune from tune file depot.
    Apr 2010
    Ok I have got it to work. I had to go into Edit / properties / Options and tick the "allow CAX files to modify operating system memory for some controllers"
  1. COS3 and lean cruise????
    By schwoch1 in forum Custom Operating Systems
    Last Post: June 13th, 2011, 10:07 AM
  2. can a lean idle or going lean during light cruise harm the engine?
    By ryans1000 in forum General (Petrol, Gas, Ethanol)
    Last Post: November 3rd, 2009, 01:44 PM
  3. Lean cold start COS3.
    By onfire in forum Custom Operating Systems
    Last Post: July 18th, 2009, 02:10 AM
  4. COS3 and COS5 lean cruise PE Mode AFR error
    By ringram in forum Custom Operating Systems
    Last Post: August 16th, 2007, 07:25 PM
  5. Lean Cruise and Cruise Control
    By neil in forum Tuning For Economy
    Last Post: July 9th, 2007, 09:42 PM
