Page 2 of 2 FirstFirst 12
Results 11 to 14 of 14
Thread: E38 IVT table required
    Yep, got the cax file and it works. I loaded up a tune for that os and loaded up the modified one I did with hpt and it read the correct values. (3.96 instead of 7.92)
    This will come in real handy when I setup flex fuel for my brothers car which will be running 100lb injectors.
    Jan 2013
    can you share the file for others to leverage?
    i just bought credits to tune a 08 vette and now it looks like i need to use HPT because they have the ivt table for proper injector scaling.
    its unfortunate i had to buy hpt because they have supported newer gm gas vehicles so much better than efilive even though efilive has the superior platform.
    this is for 7.5, you will need to save into new file and put in the required folder location.
    OS-12617631
    [TU0049]
    ; Description
    DESC.001 = IVT Weighting Coefficient - AFR Term.
    DESC.002 =
    DESC.003 = Referenced to the Ethanol % of the gasoline being used.
    DESC.004 =
    DESC.005 =
    ; Seg Caption Major Minor Vis Dis 2D Grp
    VIEW = 2 "IVT Weighting Coefficient - AFR Term" "Fuel" "General" 2 2 0 0
    ; Address(es) BitOff Bits Typ Inv
    ADDR = 1E5E9C 0 16 UNM 0
    ; Units Factor Offset Prec MinLimit MaxLimit MinUser MaxUser
    SI_SLOT = Factor 0.003906309 0 2 -128 128 -128 128
    IM_SLOT = Factor 0.003906309 0 2 -128 128 -128 128
    ; Body Col Row
    ULABELS = . . .
    ; Enumerations
    SI_ENUM = .
    IM_ENUM = .
    ; Units Labels
    SI_COL = Factor """AFR Term"""
    IM_COL = Factor """AFR Term"""
    SI_ROW = Ethanol% "0,10,20,50,80"
    IM_ROW = Ethanol% "0,10,20,50,80"
    Jan 2013
    that worked, thank you so much
  1. E38 and T43 stock files required.
    By TuneMaster in forum E37, E38 & E67 PFI ECM's
    Last Post: September 19th, 2014, 12:35 AM
  2. No A/C torque reduction table in E38 tune? B4358 spark table?
    By Mean Green Z28 in forum E37, E38 & E67 PFI ECM's
    Last Post: June 19th, 2014, 01:30 AM
  3. Minimum Sensors required on an E38 (BBC)
    By NateD4 in forum Petrol / Gas
    Last Post: July 21st, 2011, 07:55 AM
  4. 2009 E38 & E67, software update required
    By GMPX in forum E37, E38 & E67 PFI ECM's
    Last Post: January 15th, 2009, 05:55 PM
  5. IVT..........Let's talk.........
    By Redline Motorsports in forum Gen IV V8 Specific
    Last Post: December 17th, 2007, 03:19 PM
