Results 1 to 6 of 6
Thread: No Burnout with TCS and Stabilitrak off still...
Hybrid View
    Lifetime Member LBZoom's Avatar
    Jun 2008
    Default No Burnout with TCS and Stabilitrak off still...
    Hey Guys,
    Have a customer with a 2011 LML, his truck won't do a burnout for some reason. It's a 2500, and he says he read where you had to hold the button long enough to turn the stabilitrak off, etc.... still doesn't do a burnout. I've played with a few settings and haven't had any change at all. It goes to about 2500rpm then drops right back down, and keeps on doing it.
    Only thing I don't have is a video showing the message that says "Stabilitrak Off" but I'm assuming he knows enough to have verified that it was working when he held the button down.
    Anyone else ran into this, and have any insight on what could be going on?
    Thanks!
    Peace Through Torque
    Punisher Performance DSP5 Tuning, PPE Dual CP3's, 68mm Fleece Cheetah, Punisher Built trans w/ Suncoast Parts, Airdog 165, SoCal 100% Overs, ARP Studs
    2013 NHRDA Sportsman World Champion
    www.PunisherPerformance.com
    Aug 2008
    Good question.
    Lifetime Member DURAtotheMAX's Avatar
    Nov 2005
    Its probably driveline protection algorithm in the TCM (or ECM). Turning off TCS and ESC (by holding the button for 5 seconds) should allow you to do all the burnouts you want.
    Is brake-torque-management disabled in the tune?
    2005 Silverado, CC/SB, 4x4, LT, LILLY/Allison
    12.9s @ 108 mph
    many thanks to Ross and Paul
    Jun 2008
    Quote Originally Posted by DURAtotheMAX View Post
    He said he's holding the button for 15 seconds I believe. All torque management is off, and I've used the same settings as I do on all of the LML trucks we tune. See attached images for the settings most recently applied.
Name:	BTM Flags.JPG
ID:	19038Click image for larger version.
Name:	BTM Flags 2.JPG
    Aug 2008
    It is the stabilitrak that is doing it. I just couldn't get mine to turn off. Thank you Ben for pointing it out. I know my tuning was not the listing factor there. It works now.
    Aug 2008
    Try making b0401 158, b0402 157, b0403 100, b0404 99, b0405 2418, b0406 2400, b0407 1476. See if that fixes it.
  1. Take off issues after burnout
    By BAD364 in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: April 24th, 2011, 02:34 AM
  2. 09 CTS-V 6MT - Service Stabilitrak issue
    By ChurchAutoTest in forum E37, E38 & E67 PFI ECM's
    Last Post: March 18th, 2011, 04:06 AM
  3. TCS and Stabilitrak??????
    By Rhino79 in forum E37, E38 & E67 PFI ECM's
    Last Post: May 18th, 2010, 04:23 AM
  4. Stabilitrak on TBSS
    By mwalls54 in forum Gen IV V8 Specific
    Last Post: May 6th, 2007, 11:43 AM
  5. Torque management, TCS, TCS fast torque loss
    By AGRO in forum General (Petrol, Gas, Ethanol)
    Last Post: October 2nd, 2006, 05:16 AM
