Page 2 of 7 FirstFirst 1234 ... LastLast
Results 11 to 20 of 64
Thread: Calc vet.
  1. #11
    Aug 2012
    i havent been able to figure out screen shots yet do i need to disable ve to do this i will check those tables above thank you for your help someday i hope to make better sense of it all
  2. #12
    Aug 2012
    my b3618 is in lambda not sure what to do to set eqr to 1.175 or what you mean and why 0.020 on b3609 b3610 just curious as to why not 0.......and again thank you for all help
  3. #13
    Aug 2012
    maybe I'm closer than i think i changed units on my b0101 to g*k/kpa which is what my map shows and they have a closer relationship did short log on way home from work getting map data from 0.0 -1.5 might go for drive see what happens. Before i was getting numbers like 0.1-0.3 and was looking at B0101 with numbers 13.23-19... and got real frustrated hope im not setting my self up
  4. #14
    Quote Originally Posted by dirtymaxlb7 View Post
    See post #2 here: Hosting-an-Image
  5. #15
    In tunetool, go Edit->Properties->Display and set Commanded Fuel Units to EQR.
    We're using this convention to avoid ambiguity:
    - commanded fueling is in EQR.
    - wideband measurement is in Lambda.
    The correction factor (aka BEN) is then easier to remember:
    wideband_lambda x commanded_eqr
    0.020 s on B3609, B3610:
    this avoids zero which may have a special meaning (depending on who's experiment you look at).
  6. #16
    As you do this, are you also applying the SELBEN correction to B5001 MAF table...?
    I need to see both maps...
  7. #17
    Aug 2012
ID:	19654 Click image for larger version.
ID:	19655 and this is new log Log_0006.efi
  8. #18
    Aug 2012
ID:	19657 Click image for larger version.
ID:	19658 are these what you wanted?
  9. #19
    Aug 2012
    my dynamic air pid stopped working no idea why it was working and I'm not sure how i got it to then i fought with it for days then all of sudden it worked made log and wideband didn't now opposite this os is not in list so i'v been trying to figure that out but i get lost wish i could just lock myself in a room for couple days and work this out the guidance has been awesome though my navigation skills are picking up and thats bound to make things easier to remember and understand
  10. #20
    In both map properties, on the Data tab, set Precision to 3.
    ( also, in the MAF-like map properties, goto the Cell tab and constrain the cell width )
    Without seeing more decimal digits, MAF looks to be close, and VE seems close.
  1. Replies: 83
    Last Post: September 5th, 2023, 12:30 PM
  2. Calc VET Again
    By pormgb in forum Gen III V8 Specific
    Last Post: September 8th, 2013, 03:54 AM
  3. Help on my first calc vet
    By 400ss in forum Gen III V8 Specific
    Last Post: January 25th, 2013, 10:18 AM
  4. Calc VET
    Last Post: August 28th, 2011, 10:39 AM
  5. Calc.VET, VET Map Average is all 0.0?
    By n8dogg in forum Gen III V8 Specific
    Last Post: July 15th, 2011, 02:20 PM
