Results 1 to 7 of 7
Thread: 99-05 PCM Circuit 1020
    Feb 2008
    Default 99-05 PCM Circuit 1020
    Can someone tell me what circuit 1020 does in the PCM? Its located in the blue connector (C1) Pin 75. Cars (LS1) don't use it but the trucks do. I realize its an ignition hot, but just wondering why the cars use it and trucks don't.
    Thanks in advance.
    I'm looking thru 2001/2002 F-car schematics and I don't see circuit 1020... I'll tear my hair out.
    Lifetime Member SS2win's Avatar
    Feb 2005
    looks like switched 12v to me but I don't know why. Pink wire....
    2001 Camaro SS
    EFILive Custom OS3
    Mar 2007
    FWIW - I have seen this circuit labeled as "PCM Ignition Supply - Off/Run/Crank Voltage" and "Ign 0 fuse - Acc/Run/Start Voltage". Not sure if it's doing something special or not, but those are some of the descriptions I have seen in the truck / van schematics.
    I looked in the 2001 F-car connector diagram, C1:75 is listed as not used.
    Mar 2007
    joecar,
    Correct, it's not used in the Camaros. It appears to only be used in the trucks / vans.
    Jul 2003
    Wonder if its for remote start features?
  1. P0654 Engine Speed Output Circuit
    By jet231 in forum Gen III V8 Specific
    Last Post: June 16th, 2015, 07:22 PM
  2. Ethanol Sensor on MAF circuit LS1
    By macca_779 in forum Petrol / Gas
    Last Post: January 24th, 2014, 02:01 AM
  3. Knock sensor circuit low signal...
    By VTC_WS6 in forum Gen III V8 Specific
    Last Post: July 13th, 2013, 06:58 PM
  4. Auxillary ect sensor/efan circuit
    By johnmaster in forum Gen IV V8 Specific
    Last Post: June 27th, 2011, 03:08 AM
  5. Need help with P0200, fuel injector circuit
    By Ladyredhawk in forum General (Petrol, Gas, Ethanol)
    Last Post: September 25th, 2006, 03:06 AM
