Results 1 to 6 of 6
Thread: Trans Tuning
    Feb 2018
    Default Trans Tuning
    So, is EFI live able to change the 3/4 shift points in tow haul? I have messed with the tables and axis points, and it will still shift from 3 to 4 at 55 mph without fail.
    Any ideas or is that just the way it is?
    Thanks!
    Feb 2018
    Crickets. I assume that is just the way it is, the tables are basically for show, since changing them does nothing.
    Senior Member Jim P's Avatar
    Nov 2019
    There's other parameters that must be changed in order for those tables to be able to function. There is a set boundary window for which each shift is allowed to occur within, move the 3-4 shift tables outside of the boundary window and it gets ignored and defaults to the boundary window.
    Feb 2018
    Thanks Jim, so does the standard EFI software have access to those parameters or is it the user defined ones?
    Nov 2019
    User defined parameters is needed
    Feb 2018
    Great, and you can't get them now right?
  1. GM495HP Crate Engine Idle Tuning and T42 4L70E Trans tuning
    By Schwanke Engines in forum E37, E38 & E67 PFI ECM's
    Last Post: August 24th, 2018, 04:39 AM
  2. Replies: 1
    Last Post: April 6th, 2016, 02:31 PM
  3. Need trans tuning help
    By Gregs in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: April 1st, 2010, 04:09 PM
  4. Need help with trans tuning..
    By BowlingSS in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: January 24th, 2010, 01:58 PM
  5. Tuning a trans
    By sheamus in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: December 17th, 2008, 06:16 AM
