Results 1 to 10 of 11
Thread: Multiple gear shift speed table
    Feb 2006
    Default Multiple gear shift speed table
    Been going through t43 calibrations and adding a lot of undefined tables to test, some of the late vf commodore ones don't have the the tapshift speed's defined so i found & added them, but i did them as separate tables per gear, but i'd like to make them look just like the normal efilive defined tables where all the upshift & downshift tables are in 1. But if I set the start point of the hex data to include the multiple gears values, it also includes the start header/seperator for the next gear.
    Standard Efilive Table
    [D9796]
    ; Description
    DESC.001 = TUTD Shift Settings.
    DESC.002 =
    DESC.003 =
    ; Seg Caption Major Minor Vis Dis 2D Grp
    VIEW = 4 "1-2 Shift" "Shift Control" "Tap Up/Down Shift Speeds" 2 2 1 0
    ; Address(es) BitOff Bits Typ Inv
    ADDR = 1E7F90 0 16 UNM 0
    ; Units Factor Offset Prec MinLimit MaxLimit MinUser MaxUser
    SI_SLOT = KPH 0.0078125 0.0 1 0 512 0 512
    IM_SLOT = MPH 0.0039060 0.0 1 0 318 0 318
    ; Body Col Row
    ULABELS = . . .
    ; Enumerations
    SI_ENUM = .
    IM_ENUM = .
    ; Units Labels
    SI_COL = "Gear Change" "1->2"
    IM_COL = "Gear Change" "1->2"
    SI_ROW = APP% "0.00,6.25,12.50,18.75,25.00,31.25,37.50,43.75,50. 00,56.25,62.50,68.75,75.00,81.25,87.25,93.75,100.0 0"
    IM_ROW = APP% "0.00,6.25,12.50,18.75,25.00,31.25,37.50,43.75,50. 00,56.25,62.50,68.75,75.00,81.25,87.25,93.75,100.0 0"
    [D9797]
    ; Description
    DESC.002 =
    DESC.003 =
    VIEW = 4 "2-3 Shift" "Shift Control" "Tap Up/Down Shift Speeds" 2 2 0 0
    ADDR = 1E7FB4 0 16 UNM 0
    ; Body Col Row
    ULABELS = . . .
    ; Enumerations
    SI_ENUM = .
    IM_ENUM = .
    ; Units Labels
    SI_COL = "Gear Change" "2->3"
    IM_COL = "Gear Change" "2->3"
    Jul 2003
    very nice... any trans table defined is good.
    Tre-Cool, Thanks for posting. It takes time and effort to locate tables.
    Feb 2006
    I haven't posted the full cax file. my question is still around how or if it's possible to define all the gearshifts in 1 table vs individual.
    Jul 2003
    it is possible.
    what do you want to accomplish? which tables you want to see in a single table?
    He wants all the normal upshift/downshift curves together in a single table (so they can be compared).
    Feb 2006
    yeah, Joe gets it.
    Basically i found all the missing tapshift tables for os 24267577, but between each 17 items there is a 00 11 hex block for the next 17 items.
    i've tried to use a comma between addresses with each address specified but having no luck.
    Banned
    Dec 2022
    Thanks for all the info.
    Regards,
    oil and gas training courses in Ghana
    Did you put quotes around the list of comma separate addresses?
    Feb 2006
    that got it, had to do it like this.
    """value1"",""value2"",""value3"",""lastvalue" ""
  1. truck wont shift 2-3 rd gear at wot after tune?
    By miss behavin 83 in forum Gen IV V8 Specific
    Last Post: February 24th, 2016, 05:53 AM
  2. 6 speed not updating current gear fast enough
    By dieselmd in forum Allison 5 & 6 Speed
    Last Post: October 18th, 2015, 06:56 AM
  3. 3rd gear flare shift
    By mstordahl in forum Cummins 5.9L
    Last Post: November 24th, 2012, 07:35 AM
  4. 3rd gear flare shift
    Last Post: June 5th, 2012, 08:05 AM
  5. Car dies after fast shift to third gear
    By Highlander in forum E37, E38 & E67 PFI ECM's
    Last Post: April 16th, 2011, 11:03 AM
