Results 1 to 2 of 2
Thread: E98 Vats Relink, ECU Unlock
    Feb 2006
    Default E98 Vats Relink, ECU Unlock
    Got asked to look at an ecu yesterday that someone had bricked with alientech.
    They flashed in a tune file & corrupted the VIN etc. long story short i put a spare one i had into the car, unlinked ecm via gm's techconnect but it would not relink.
    I even tried the scan tool relearn and it gave an error straight away, so im guessing this is not functioning yet?
    2nd question after finding the unlock code on bench, the v8 scantool doesn't seem to have a unlock function to put the seed/key combo back to stock, should this be working?
    Cheers
    Dave
    Feb 2006
    so i can read/write fine, can even use the efilocker feature, but as soon as i send a stock tune back into the ecu the seed/key combo changes to 90DA/0094.
    is it possible to change the lock code to a matching stock algorithm so i can do a flash straight from tis2web/techconnect.
  1. E39a VATS relink
    By supra8 in forum General
    Last Post: November 27th, 2021, 05:13 AM
  2. VE Series 2 - E39 VATS relink / relearn
    By luke1 in forum E39, E80, E82 & E92 SIDI ECM's
    Last Post: November 4th, 2019, 01:38 AM
  3. VATS relink with scan only?
    By mr.prick in forum FlashScan V1
    Last Post: July 9th, 2009, 11:58 AM
  4. How do I perform VATs to BCM Relink?
    By KAZ MotorSports in forum Gen III V8 Specific
    Last Post: May 12th, 2008, 12:41 AM
