Results 1 to 4 of 4
Thread: Injector swap issues
    May 2020
    Default Injector swap issues
    I have a 99 LS1, basically stock engine with a turbo, that was tuned by someone else. It had Deka 60s in it and Ran fine with no issues. I swapped in some Deka 80s with no others changes and put in all the injector data and have had nothing but problems. Turns out the Deka 60 data was never really correct as all they did was enter the flow rates and nothing else and it was tuned like that. So now have done nothing but change the flow rates to 80 and at start up it's lean for a bit, then hits 14.7 for a bit, then goes rich. What makes it more confusing is that there is no real change to the injector pulses so I am not sure what the heck is going on. I have attached a log of what it's doing. If anyone has ideas of what to look at it would be appreciated.
    Dec 2016
    Assuming you have real Deka's and not a chinese knockoff set. The biggest issue with the Deka 80's is that they are a straight stream flow instead of a cone flow like the 60's. Huge difference in atomization and wall wetting. If you find it runs more consistent when engine is at 200f or hotter, that gives a decent clue. Good luck.
    Those injectors can make you go crazy trying to dial them in if this is your first time.
    Nov 2014
    but maybe can make more power due to concentrated injection pattern?
    https://www.racetronix.com/product/I...0Worksheet.pdf
    https://siemensdeka.com/specsheets/FI114992.jpg
  1. Injector swap in prep for boost
    By moatsman5000 in forum General (Petrol, Gas, Ethanol)
    Last Post: December 20th, 2019, 07:04 AM
  2. 411 Swap 96-02 injector #1 not firing
    By HellKnightHicks in forum Vortec V6/V8 Specific
    Last Post: May 19th, 2017, 04:44 AM
  3. injector swap question
    By vcls1 in forum Gen III V8 Specific
    Last Post: March 20th, 2012, 02:21 AM
  4. OS swap issues
    By Pusher in forum Gen III V8 Specific
    Last Post: March 3rd, 2009, 07:50 AM
  5. Lean AFR after injector swap
    By vatman02 in forum General (Petrol, Gas, Ethanol)
    Last Post: February 23rd, 2008, 02:16 PM
