Page 2 of 2 FirstFirst 12
Results 11 to 13 of 13
Thread: P59 ls1b cos5 setup help!
  1. #11
    May 2014
    I just double checked the COS3 options for that OS and there is nothing for nitrous... only boost. COS5 allows you to tweak timing and fuel (dry shot) based on input pin switch, but yeah only available for 1 or 2 411 OSs.
  2. #12
    Member TJWells's Avatar
    Apr 2008
    Ok, so what's the right thing to do here? Is there a correct ecm to use that I can do a cos with nitrous options and FF? If so which OS do I use? do I use cos5? I have no issues purchasing another ECM. I am a GM parts dept. manager, I can purchase one through my dealership easy enough or used supplier. What would you guys do?
  3. #13
    Feb 2006
    Another option for the N2O timing concerns is to wire a resistor in place of the stock one. You can use the very low temperature area of the Spark IAT table {B5911} to retard the timing as you deem necessary. Make sure you update the tables {B5943} & {B5944} to "1" for all values at the minimum. I made a quick schematic for an earlier PCM but I'm sure you can use this jpg to get an idea of what to do electrically.
    AlClick image for larger version.
  1. P01 vs P59 for GMT400
    By Thelochnessmonstah in forum General (Petrol, Gas, Ethanol)
    Last Post: December 28th, 2021, 04:57 AM
  2. Read DTCs on LS1B bench setup?
    By DrX in forum General (Petrol, Gas, Ethanol)
    Last Post: May 6th, 2021, 11:48 AM
  3. Bricked P59 tune
    By greasess in forum Gen III V8 Specific
    Last Post: August 3rd, 2020, 05:26 AM
  4. COS5, how do I setup a 2 step?
    By tdmkr496 in forum Custom Operating Systems
    Last Post: August 26th, 2014, 06:22 AM
  5. COS5 and nitrous setup ?
    By RandyWS6 in forum Gen III V8 Specific
    Last Post: June 2nd, 2008, 12:36 PM
