Results 1 to 3 of 3
Thread: B8802 Commanded Power
    Aug 2016
    Default B8802 Commanded Power
    Good day,
    I'm chasing a couple of throttle closure issues, and I noticed that B8802 Commanded Power has TPS% as the column axis, yet the description says Pedal Position is the column link. In the link.ini file it says SAE.TPS is the column link. Since there is no SAE.TPS listed in the pids selection, I'm assuming that TP in ECM-Generic is the correct PID to log.
    Having said that, which one is the correct column axis, TP or Pedal Position?
    generally the etc ecu's use GM.APP for accelerator pedal position
    GM.ETCTP for the actual blade position.
    Aug 2016
    I've always used ETCPP1 for the pedal and TP for actual throttle position and it's always worked as I would expect. It's just that when trying to link the table to the scan tool, the descriptions are all out of whack.
  1. Intermitent commanded A/F to 16:1
    By mysunnshine in forum Gen III V8 Specific
    Last Post: May 13th, 2019, 01:47 AM
  2. Commanded AF
    By FreshDA9 in forum Gen III V8 Specific
    Last Post: October 22nd, 2012, 10:23 AM
  3. AFR Commanded... Where else other than PE???
    By Behold in forum General (Petrol, Gas, Ethanol)
    Last Post: October 27th, 2011, 01:27 AM
  4. Low power mode and power cycle?
    By SV8346 in forum FlashScan V2 BB Logging
    Last Post: March 23rd, 2008, 11:40 PM
  5. commanded afr
    By 69camaro5speed in forum General
    Last Post: December 29th, 2005, 05:42 PM
