Results 1 to 3 of 3
Thread: flashscan v3
    Dec 2023
    Default flashscan v3
    Hello...I'm a potential buyer of the FlashScan V3, but I need help to determine everything I need.
    Situation:
    I'm have a 2013 Cadillac Escalade ESV Platinum, that I'm changing the transmission valve body in it. and it requires Transmission reset. What all do I need to accomplish this the EFILive Hardware. Any guidance is greatly appreciated.
    Note: I will not be using the hardware for tuning...I just need it to reset TCM and PCMs
    Thanks,
    Depends on how the valvebody TECM is setup.
    Some you can get are preprogrammed for your truck so you can put them in and go.
    Others come blank and need to be taken to the dealer to be programmed for your truck.
    Lifetime Member Cougar281's Avatar
    Jan 2006
    For what you're looking to do and what a v3 costs, since you said you're not looking to do tuning, you'd be better off getting a MDI2 (I got mine here https://gmtoolsandequipment.com/en-U...KU=EL-52100-AM) and then you'd have the dealer hardware, you could buy a vin license for the vehicle for $45 from acdelcotds.com which will give you two years of programming access for all modules for that VIN. I'm not sure EFILive can do full programming of a brand new blank module.
  1. New to the v2 flashscan
    By andysc3 in forum Gen III V8 Specific
    Last Post: September 11th, 2019, 02:41 AM
  2. FlashScan V2 help please?
    By e.carter in forum FlashScan V2
    Last Post: June 12th, 2013, 03:47 PM
  3. When will FlashScan do this
    By Dirk Diggler in forum Lounge
    Last Post: December 28th, 2006, 09:48 AM
  4. LC-1 and FlashScan
    By BowlingSS in forum General (Petrol, Gas, Ethanol)
    Last Post: February 13th, 2006, 07:56 AM
  5. Will flashscan
    By mgarfias in forum General (Petrol, Gas, Ethanol)
    Last Post: December 2nd, 2004, 05:27 PM
